Old 15th July 2008, 02:12 PM   #1
Default how will you make a 2ohs coonnection
i have 1 10'jbl dvc 2ohms and a 12" jbl dvc,2ohms subs.
my amp can handle 1,2 and 4 ohm
1) can i connect the two subwoofers in together?
2)what connection should i use?(some says that the 2 subwoofer in series will have 4 ohs connection,while in parrallel it will have a .5 ohms.my amps cant handle .5ohms)
3)what connection should i do to have a 1 ohms connection>?
tnx
Old 15th July 2008, 02:33 PM   #2
In series to be safe for your amp.
In parallel the load is 1 Ohm,your amp may or may not like it.
xxx I should correct my spelling xxx
Old 15th July 2008, 02:35 PM   #3
Corax is offline Corax  Germany
Two voice coils of 2 ohms in series will result in a total of 4 ohms.
Both in parallel will give a total of 1 ohm and not 1/2 ohm.
If your amp is capable of driving 1 ohm speakers feel free to connect them parallel to a mono amp.
However I would Recommending to use a two channel amplifier with seperate volume controls because of the different mechanical parameters (in particular diameter and possibly different Xmax and Pmax) of the chassis (10" and 12") besides other more or less important parameters.
Old 15th July 2008, 08:17 PM   #4
Speakerholic
Cal Weldon's Avatar
If there are 2 ohm DVC you might want to consider running the two coils on each woofer in series and then paralleling the two woofers to get back to 2 ohms. Even if your amp is stable a 1 ohm, 2 ohms will run it cooler and probably last longer.
Question: Why do you want to use two different woofers? They are never going to sound the same if you are asking them to cover the same frequencies so this is not, IMHO, a good idea.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Make it worse to make it better??? moray james Planars & Exotics 23 12th May 2008 11:08 AM
how to make an amp PimpMyRide Solid State 4 16th November 2005 07:11 PM
How make make a microchip, from a program? multiplexor Everything Else 1 20th February 2004 01:24 PM
Page generated in 0.15832 seconds (44.03% PHP - 55.97% MySQL) with 10 queries
