Old 13th July 2008, 04:25 AM   #1
Account Disabled
Default Iso-barik?
So i searched the forums for this, and the best i could figure was that it halves the vas, and lowers the efficiancy. does anyone have experience with these?
I've been considering building a subwoofer, for me space is more of a problem than low efficiency. is this a good option, or is it too much for a beginner like me?
Old 13th July 2008, 10:27 PM   #2
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
Here's a link with a bunch of different Isobaric info topics you can click on.. http://mobile.jlaudio.com/search.php Type ''isobaric ''in the search bar and they should all come up.
Dave
Old 14th July 2008, 06:37 PM   #3
Account Disabled
awesome! thx for the link man!
Old 15th July 2008, 01:20 AM   #4
dangus is offline dangus  Canada
The space saving isn't quite as good as you'd think. The second driver plus "tunnel" occupy some volume. You may be better off mass-loading a driver since this achieves the same effect (lower efficiency) for less cost, and will give a smaller enclosure since you don't need that second driver. Or just start with a more suitable driver; saving the cost of a second woofer should allow a wider choice of good drivers.
The one time I intended to build an isobaric box, I forgot to allow enough clearance for the tunnel, and the resulting single-driver box sounded great, just with a couple dB hump which was quite pleasant.
Old 17th July 2008, 12:32 AM   #5
The first sub I built was an isobaric design. I needed to build it into the back wall of my celica, so I would still have enough room to lay my bike in the back with the rear wheel on.
I turned one driver magnet outward to save the space taken up by a tunnel. It was a really,really great sounding sub.
JJ
Old 17th July 2008, 03:00 AM   #6
Jonny Hotnuts's Avatar
I have on more than one occasion built isos with cheap drivers (jensen 12" for instance) and they sounded 100% better than they did in a standard enclosure.
On that note, I have never heard an iso setup that I didnt like!
If you do a face to face, make sure you have a sepprator between them (I used .75 mdf) or the drivers will distroy eachother.
Good luck and ISO!!!
Compound , Iso-Barik Lindell Subwoofers 20 9th October 2007 02:35 AM
iso-barik sub odysseybmx414 Subwoofers 3 13th March 2006 07:01 PM
iso-barik subwoofer busterno1 Subwoofers 0 9th September 2003 07:41 AM
Page generated in 0.11392 seconds (64.72% PHP - 35.28% MySQL) with 10 queries
