I have a DVC woofer, which I would like to use in a computer sound system. I want to hook up one (stereo) channel to each voice coil. I made measurements for 3 cases, with results as follows:
Measurement 1 – L/H and R/H voice coils wired in series fs = 61.9 Hz DCR = 7.43 ohms Qms = 5.3 Qes = 0.87 Qts = 0.75 Le = 1.43 mH SPL = 87.2 dB BL = 7.1 T*m Mms = 15.25 g Vas = 12.3 liters Measurement 2 – R/H voice coil measured, L/H v.c. shorted out fs = 61.9 DCR = 3.55 ohms Qms = 1.43 Qes = 1.72 Qts = 0.78 Le = 0.20 mH SPL = 84.2 dB BL = 3.5 T*m Mms = 15.25 g Vas = 12.3 liters Measurement 3 – R/H voice coil measured, L/H v.c. left open fs = 62.6 DCR = 3.55 ohms Qms = 5.3 Qes = 1.60 Qts = 1.23 Le = 0.38 mH SPL = 84.8 dB BL = 3.6 T*m Mms = 15.25 g Vas = 12.6 liters What puzzles me is the big difference in the Q's and the Le, for measurements 2 and 3. I suppose the fact that there is a measured difference for shorted vs. open could allow the speaker builder to choose whichever configuration suits the design best. But at the same time, if only one configuration matches the actual performance when both coils are being used (each channel for stereo for example), then it would be good to know which one is more appropriate. Does anyone have a good explanation for what is happening (suspect it is electromagnetic effect somehow)? Which values should be used for designing a box and crossover? Dave R the 200% Norske
- Dave R the 200% Norske |
#2 |
Use measurement 1 or 2 for designing the box.
Do some searches on this board for DVC wiring, you will find a lot of information.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
Ports rule! |
#4 |
thanks for all of the good info.
I guess it makes sense to use the "shorted" measurement. Looking at the measurement when the v.c.'s are hooked up in series, the Qts is close to the value for the shorted measurement. Dave R
| Home wound inductors. | Big_Bill | Multi-Way | 10 | 29th July 2009 09:16 PM |
| An SE 813 OPT?? SP. Wound??who zat? | Richard Ellis | Tubes / Valves | 1 | 10th May 2009 09:11 PM |
| Anyone wound SE transformer for 6c33c-b? | Alastair E | Tubes / Valves | 75 | 14th February 2008 06:55 PM |
| Recklessly wound inductors? | mr_push_pull | Multi-Way | 2 | 14th January 2006 02:50 PM |
| Custom wound speakers? | eeka chu | Multi-Way | 7 | 27th November 2004 10:31 AM |
| Page generated in 0.11682 seconds (61.91% PHP - 38.09% MySQL) with 10 queries |
