Old 8th July 2008, 12:40 PM   #1
Default 2 x XLS10 / vented box + added mass?
Lo,
I'm messing about with Winisd at the moment looking at configurations for 2 subs to form the bottom sections of a new loudspeaker project.
I'm thinking of side firing subs mounted back to back in a push push configuration to cancel vibrations, in a vented enclosure.
If I go for a 60l enclosure tuned to 24Hz and add 25g mass to each cone, I get a modelled response that looks like the attached pic. This looks good to me but is adding mass a bad idea? I don't want to end up buying 4 x XLS drivers and 2 plate amps if I'm likely to realise a totally different response from actual speakers.
Should I just stick to using a PR and single driver per side instead and try to deal with the vibrations induced in the rest of the cabinet in another way?
Old 9th July 2008, 01:36 PM   #2
Sorry - I didn't search properly - would a mod please delete this thread - apologies.
Vas measurements by added-mass method in Speaker Workshop tcpip Multi-Way 26 1st June 2009 09:07 PM
Measuring subwoofer TSP: Added mass method best practise Groundloops Subwoofers 1 16th February 2009 11:09 PM
Formulas to calculate new TS values when mass added macky888 Multi-Way 8 14th February 2004 06:36 PM
How do you measure Vas by added mass method? Circlotron Multi-Way 1 28th December 2002 08:11 PM
"mass added to cone" I'm confused about it's meaning Jimmy154 Multi-Way 12 8th July 2002 02:53 AM
Page generated in 0.10358 seconds (53.47% PHP - 46.53% MySQL) with 11 queries
