ok guys I haven't had much chance to check in the forums for a long time now and now that i got my comp built I'm looking at attempting a budget build $300 complete sub woofer. I'm looking at a very simple set up, Basically cut the cabinet, plug and play sort of set up right now. Birch is my choice of cabinet material, 1/2" is in consideration but i think i might as well do 3/4" for $10 more. As expensive as everything is nowadays a $300 build of decent quality is becoming more of a challenge. Anyways, I'm thinking of pairing up a Dayton driver rated at 300 watts rms @ 4 ohm with this bash amp. Very simple like i said. As far as enclosure goes a ported 4 ft^3 @ 28 Hz box seems best, as this will be 3/4 music use and the rest computer gaming and some movies. Anyways I would appreciate some input on this and if anyone knows of anything better off let me know.
BTW I have had bassbox pro for so long i done forgot the name of the freeware enclosure response modeling software i used to spend hours on, i know it's a very common program but i can't put my finger on it's name even after some goggling. Can someone help me out? lol |
#2 |
winisd ur thinking of?
#3 |
yes winisd, lol thanks
#4 |
The BASH seems cool, unless you're thinking of using the plate amp's high-pass section for your satelites. From the picture of the unit, it seems to have no high pass, though I don't have one and can't say for sure.
I missed this on my first several glances at the unit, so I thought I'd point it out... |
#5 | |
http://www.mach5audio.com/zen/index....roducts_id=182 |
#6 |
Speakerholic
I'd take the sensitivity rating with a grain of salt.
#7 |
hmmm bigger is always better but damn that price just keeps going up and up, i remember when it was $58 plus $18 shipping
#8 |
http://www.chokes.com/gw15xp.html
My personal fav, it's actually around 99.2 dB with my SPL meter. |
#9 |
Hmm, without knowing all the details of your measurement it's meaningless in the scheme of things, especially since its published specs calc a ~93.2 dB/W/m half space reference efficiency, though at 2 ohms its sensitivity is ~99.22 dB/2.83 V/m (4 W).
Like any other low Qts, Xmax driver though, it takes a huge box to go low with any authority at low distortion. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#10 |
it's 99.2 in a 5 cubic foot sealed box.
| Tony Gee's Low Budget Speaker - Build Thread | mrevie | Multi-Way | 27 | 18th April 2011 11:40 PM |
| newb build; budget floorstander in UK | matteroftaste | Multi-Way | 11 | 8th May 2007 08:36 AM |
| First time build help needed budget oriented | sbrunkow | Multi-Way | 1 | 24th October 2006 05:23 PM |
| budget 3-way using audax, is it gonna be good? | _henry_ | Multi-Way | 5 | 31st October 2005 03:45 AM |
| not sure of forum, good budget amp. | conig | Multi-Way | 23 | 24th May 2003 07:59 PM |
