Rebel Samurai!
For approx $150 what is the plate amp of choice?
MCM? http://www.mcmelectronics.com/product/50-6263 PE? http://www.partsexpress.com/pe/showd...number=300-804 I saw some talk about a rythmik, but the links I found are dead. Anything else I should know about? Whadya all like? Thanks! |
#2 |
In that price range the Apex "Senior" Subwoofer Amp is a good deal. More power for the money compared to the amps you listed.
http://apexjr.com/Apexsenior.htm |
#3 |
Its more expensive than the plate amps.. but its worth it.
http://www.creativesound.ca/details.php?model=A401 http://www.diyhifisupply.com/diyhs_speaker.htm I have the A400, incredibly well built with a LOT of quality power supply. For about 150 you might want to consider a DUAL VC woofer and utilizing 2 plate amps, for that I'd recommend these: http://www.mcmelectronics.com/product/50-6272 Low cost yet decent DVC woofers can be purchased from Parts Express here: http://www.partsexpress.com/pe/showd...number=295-480 http://www.partsexpress.com/pe/showd...number=295-485 http://www.partsexpress.com/pe/showd...number=295-490 With an amp for each coil that will give you a LOT of versatility. But if you simply must have a single plate amp at around 150: http://www.oaudio.com/300W_SUBAMP.html Note that one of things you ALWAYS want is a fully adjustable phase "knob".
perspective is everything |
#4 | |
This should work ok http://www.rythmikaudio.com/products.html CSS sell the german Reckhorn which has some additional usefull features ... ohh! I see Scott have linked to that allready |
#5 |
http://home.comcast.net/~jhidley/index.html
I got some of the VT3 amps, which are 300W Sunfires, to drive my subs. Stupid cheap price. They work perfectly.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 |
Rebel Samurai!
ScottG: For about 150 you might want to consider a DUAL VC woofer and utilizing 2 plate amps ... With an amp for each coil that will give you a LOT of versatility.
--- Whoa, I think you blew my mind a little bit there, I hadn't even considered such an option. I've actually got 2 speakers coming - The shielded 10" Fosters from Mr. Hidley - I was planning an isobarik setup but also thinking I'd play around with as many configurations as possible. I'll have to think through the implications of setting up with 2 amps... That A400 is looking awfully sexy as well. It'd be hard to say no to that. Of course I saw the VT3 amps, but have figured myself not expert enough to build a control unit that would have the flexibility I hope to be able to afford. I figured there had to be better options than what I had so far found, thanks everyone for proving me right. |
#7 |
Hi... ( Happy 4th of July) Sale
Starting July 7th Monday I will put the Apex "SENIOR" on sale for that week: Normally on sale for $145.00 for the week of JULY 7th only to DIY AUDIO Members and you must mention it. It won't be on the website $ 125.00 ea Steve @ Apex Jr. |
#8 |
$150 is not that far away from a used "pro" power amp, or consumer basic power amp. Watch the classifieds, eBay (for amps within pickup distance), music stores and pawn shops.
| Plate Current VS Plate Voltage Graphs | Captn Dave | Tubes / Valves | 2 | 13th February 2009 08:57 PM |
| ECC83 - Long Plate vs Short Plate | poynton | Tubes / Valves | 16 | 17th February 2008 07:42 AM |
| 2a3, single plate-double plate? | tenderland | Tubes / Valves | 5 | 30th October 2005 09:03 AM |
| Subwoofer Plate Amplifier Base Plate supplier? | jwells777 | Parts | 1 | 11th May 2003 07:40 AM |
| Page generated in 0.16626 seconds (62.47% PHP - 37.53% MySQL) with 10 queries |
