LS3/5A Subwoofer
LS3/5A Subwoofer
Old 8th July 2008, 10:27 AM   #11
R.I.P.
Due to the limited maximum output, a matching sub will likely have
plenty of headroom, so for sealed box a plate amplifier with variable
low boost is probably the best way to proceed.
FWIW even crossed over at 300Hz, (short lived massive stereo boxes
to go with them), the low sensitivity and saturation characteristics of
the c/o components limited output to modest levels.
For small speakers unusually as standard they need using well away
walls, some manipulation of the bass end may allow closer spacing.
/sreten.
Old 8th July 2008, 02:04 PM   #12
AMV8 is offline AMV8  United Kingdom
Hi
I still use LS3/5a in one room. They sound so good on voice.
In have used them with an active sub woofer, a wharfedale unit, and that sounds fine. I have also built passsive base units for them with a 2nd order filter at 160 hz and that also sounds fine. These use wharfedale 10" base units in sealed cabinets that fit below the LS3/5A units.
As long as you do not play too loud they sound great on voice and classical music.
Don
Old 8th July 2008, 02:06 PM   #13
Hi
i should have also added that the LS3/5a sounds smooth and is easy to listen to; but does not provide much detail.
Don
LS3/5A SubwooferHide this!Advertise here!
subwoofer under bed Potato42 Subwoofers 7 13th January 2009 02:21 PM
subwoofer project, which subwoofer? Davlaf Subwoofers 12 9th November 2006 03:59 AM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
I need help with subwoofer deisign: HUGE inexpensive subwoofer hottyson Subwoofers 16 4th May 2004 03:51 AM
