I am in the process of repairing a M&K VX-7 subwoofer that I inherited from a friend. I repaired the speaker by replacing the surround. (Went well; my first such repair) But I found out the the amp is fried. From my research I've determined that the amp for this sub is (was) 50 Watts.
I would like to use this 70 Watt amp: http://www.partsexpress.com/pe/showd...number=300-784 The problem is that the speaker is a 2-ohm unit. The amp is rated for a 4-ohm load. Can I use this amp as-is? Or, should I put a 2-ohm resistor in series? |
#2 |
Are you sure it's 2 ohm?
#3 |
The speaker magnet has a sticker on it that says it's 2ohm, and I measured 2.5ohm with my DMM.
#4 |
If your not in a rush, you might want to watch ebay for the correct amp. I've seen a ton of M&K parts on there since they closed their doors last year.
#5 |
Perhaps I should try a different tack on this request. Assuming that I am going to re-amp this sub with a 70 watt, 4 ohm capable amp,
Do I: 1) See how (of if) the amp can handle a 2 ohm load 2) Place a 2 ohm resistor in series with the speaker for safety Won't anyone take a stab at this? C'mon, this must be child's play for some of you... |
#6 |
Steve at apexjr may have what you need,and is a site sponsor
http://apexjr.com/MnK100MP.htm HTH Jorge |
| Headunit repair question | spooney | Car Audio | 1 | 19th January 2008 04:26 AM |
| car amplifier repair question.... | jesimon | Car Audio | 19 | 13th June 2007 09:34 AM |
| Transformer repair question | woody | Everything Else | 6 | 19th October 2005 12:09 AM |
| tv repair question | dvd_diyer | Everything Else | 1 | 2nd June 2004 07:23 PM |
| car amp repair question!!!!!!!! | sndtch6 | Solid State | 10 | 11th April 2004 07:02 PM |
| Page generated in 0.20931 seconds (34.46% PHP - 65.54% MySQL) with 10 queries |
