In the subwoofer I'm building, there are 2 X 300VA toroids planned as close as 3inches to the subwoofer magnet. My questions are:
1. Would the toroid demagnetize the subwoofer magnet in the long run? 2. Would the subwoofer magnet polarize the transformer to saturate? Please comment. Anand |
#2 |
Let me add another thing for you to worry about:
3. Will the heat from the transformer / amp spoil the speaker cone ? |
#3 | |
#4 | |
Electrons are yellow and more is better!
![]() 2 Not likely with the distance but beware of it. How big is the speaker element and how big is the enclosure? 600 VA in a small box?
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#5 |
Peranders,
See http://picasaweb.google.com/anand.su...h/TheSubwoofer There are two 12" drivers in push-pull config. Enclosure is completely sealed and is around 130 litres. SAF is bad -- Q is good -- around 0.85 measured roughly using SpeakerWorkshop. I initially planned to plant the amp and transformers on the back panel. I'm now thinking of sqeezing them all into the pull-driver cavity. See snap 6. --Anand |
#6 |
Nice sub.
Dance4Life Tiesto4Life |
#7 |
Toroids have good suppression of lateral fields. There is a significant field coming out the top and bottom of the toroid (like a column of flux centered around the hole).
Point this away from the drivers for best results.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
| FS toroidal transformers | royboy5033 | Parts | 0 | 22nd June 2009 08:46 PM |
| Toroidal SE transformers | zogu | Tubes / Valves | 22 | 28th February 2007 09:28 PM |
| Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) | Rixsta | Pass Labs | 10 | 23rd April 2004 03:41 AM |
| Toroidal Transformers | jhead | Chip Amps | 3 | 8th March 2004 07:58 AM |
