I have two of these:
Peerless CSX-257W 24 cm bass driver with sandwich cone. power handling (continuous/programme) = 120 / 160 W resonance frequency fs = 28 Hz impedance R = 8 Ohm SPL = 88,2 dB (2,83V; 1m) Re = 5,5 Ohm BL = 10 N/A L = 2,9 mH Sd = 330 cm2 effective mechanical mass incl. air load 51,9 g Vas = 144 l Qts = 0,35 (Qms=2,56, Qes=0,4) xmax = +/- 9 mm mounting diameter d = 220 mm overall diameter d = 257 mm mounting depth (not countersunk) t = 99,6 mm I want to build a sub, but not just any sealed or bass reflex sub. I want something, anything slightly different. It doesn't have to be small but ridiculously large is also out of the question. It will likely be powered by a plate amp or sub amp like the one from Reckhorn. I was thinking about isobaric, or TL variations. or an isobaric TL iso MLTL, a tapped horn. I want it to go deep as possible while still being relatively clean. Basically I really only want the lowest octave or maybe on up to 50 or 60Hz. My room is about 6m x 6m with an 1,75m opening into another 5m x 5m room. I get good extension with my mains (4- 4" tangbands in a small array BR loading per side) but the last octave is clearly missing. So anyone with any cool ideas, please share. |
#2 |
This is only an idea. A BR box, a 4.order bandpass and a 6.order bandpass sub.
The 4.order doesn't need protection against over excursion. Boxes 1 and 3 need protection under 25Hz for cone excursion (as an example). When you are set you will be able to choose between TL, Isobaric, BR, PR, Horn, Bandpass or other. Peerless CSX-257W sub |
#3 |
Peerless CSX-257W sub-cone excursion
#4 |
Peerless CSX-257W sub-max spl
#5 |
Peerless CSX-257W sub-spl
#6 |
Peerless CSX-257W sub-vents size
#7 |
interesting suggestions. Just out of curiosity what makes you tend towards bandpass?
#8 | |
You said: "I want it to go deep as possible while still being relatively clean. Basically I really only want the lowest octave or maybe on up to 50 or 60Hz."..."I get good extension with my mains (4- 4" tangbands in a small array BR loading per side) but the last octave is clearly missing.", you decide. Look at it as an exercise to compare with other options that you will have. |
#9 |
Well, a ~14 Hz isobaric TH meets your performance goals if 320+ L isn't too big........
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#10 |
these (now unobtainable) drivers are almost too good to use for sub duty only, they have excellent low distortion response up to over 1.6 Khz, probably best used as a woofer in a 3-way. I'm getting good results using them in 90L BR cabinets tuned to the high 20s, but if you want something different, how about sealed cabinets around 40L and a Linkwitz Transform filter?
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
| NFB, how to implement here? | disco | Tubes / Valves | 0 | 12th August 2009 09:06 PM |
| How many people implement switches? | westers151 | Everything Else | 14 | 11th March 2009 02:11 PM |
| How to implement DC protection in a BTL amp??? | Leolabs | Solid State | 1 | 9th April 2007 03:57 AM |
| How to implement synchronous clocking | regal | Digital Source | 2 | 20th August 2006 02:57 AM |
| does AES/EBU help if i implement reclock? | garbage | Digital Source | 44 | 15th September 2005 03:20 PM |
| Page generated in 0.11652 seconds (77.75% PHP - 22.25% MySQL) with 11 queries |
