I built two very large main speakers and find the system performs better when using a powered sub. Originally, i thought large mains would eliminate the need for a sub. Of course i am keeping the sub and enjoying the warmth and punch it adds. Is anyone else also using a sub with large main speakers? Now i am wondering about building an even larger sub to get even more performance.
Godzilla |
#2 |
Godzilla u wii get more performance with the lower frequency more than the big front speaker. but the sub woofer driver should be respond lower than the front woofer drivers./
#3 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 |
So two powered subs are better than one? My room is pretty small. How will two subs sound different than one?
#5 | |||
hi
#6 |
Speakerholic
I run a 15" powered unit with 15" coax PA drivers to help with the bottom end. If I didn't, I'd really need to EQ.
I am of mixed minds about using more than 1 woofer unit. |
#7 | |||
With the new system I'm building the mains will be set to 40Hz via a Linkwitz xform for low level/late night music, and 60Hz and subs below that if I want to crank it. Perhaps I'll find a preference for the subs on always. Time will tell. When I added the LABhorns under my KHorns I thought I'd only use them for movies, but it turned out to be everything. Quote:
#8 | |
Yes, all typical rooms have standing waves and there's no place in a room where a ~flat response can be had with just one sub, so a 'stereo' pair is considered the absolute minimum regardless of room size. Really, due to room modes extending up into our acute hearing BW, smaller rooms typically need four or more subs spread around as does room ratios that fall too far outside a golden or acoustic one: http://www.harman.com/wp/pdf/multsubs.pdf Since down low the WLs are long enough for fairly widely spaced subs to sum, they can be smaller with the trade-off of course being more expensive than a single large one due to the extra drivers (and plate amps in some apps). GM
#9 |
So two powered subs - one each next to or near my BIBs - would sound better than one sub all by itself. Or would one of the subs need to be in another part of the room for optimal performance?
http://www.zillaspeak.com/systems.asp I have an old ACI sv12 sub. I understand i can buy another one from Meniscus Audio. Maybe two of these would really round out the already amazing sound i am getting from my stand alone BIBs. Might as well get the most performance i can while i am still alive and well! I want to treat myself really good since my operation. Do the subs have to be the same? Or can they be different. Say and 8 inch sub in a small box and a 12 inch sub in a big box. Or am i thinking about this too hard and being wasteful? Godzilla |
#10 |
Actually, per the Harmon paper, Dr. Geddes in another thread and numerous other papers, DIYers, subs near/next to the mains is almost never the best compromise positions and why wide BW mains and separate sub systems are preferred.
No, they don't and often need to be different since they're being used as much for acoustic room correction as for bass extension, a point I've periodically made. Still, unless you map the room to determine what's needed it's best to err on the conservative side and at least use the same size and adjust the tuning/level as required. GM
| Large Main Cap discharge????? | Serratoga | Power Supplies | 5 | 5th March 2008 07:35 AM |
| Shocked by Subwoofer thru Speaker Outlets of Main Amp | lews | Solid State | 50 | 17th September 2007 11:18 AM |
| Shocked by Subwoofer thru Speaker Outlets of Main Amp | lews | Subwoofers | 20 | 13th September 2007 08:16 PM |
| Picture of my main speakers | markp | Multi-Way | 6 | 19th June 2004 12:42 AM |
| Seeking comments regarding dedicated dual subwoofer use with main speakers | UncleJessie | Subwoofers | 2 | 16th April 2003 06:38 AM |
| Page generated in 0.12268 seconds (76.43% PHP - 23.57% MySQL) with 11 queries |
