Hi!
I'm about to make two small subs using the 8ohm XXLS 10" from peerless (830843). I've calculated that an internal volume of 31,5 liters will be sufficient. I would perfer 40-50 liters, but "space limitations" persuade me to go even smaller; 31,5. My calculations tells me that with a +6db boost @ 25hz and lowpass @ 40-50hz I will end up with a not-ideal, but ok curve (it will require some bad-*** amp) Do any of you agree, or is it just silly to even think about it? and by the way; I'm thinking maybe a PR as well; The peerless 10" XLS passive radiator. Will have some advantage over the closed box? My calculations show a slightly increase in sensitivity, but about the same response curve. I plan to make a hole for the PR, but put a MDF piece there to start with..., and possibly make a "signature" versjon later when I get the $$$ to buy me the PRs. ... just like Audiovector and their Mi-sub and Mi-sub signature. Silly, or ok? hot or not? yay or... no? I'm not looking for a killer sub..., only some nice tight bass... Yes, I did search the forum.., but found only projects involving bigger enclosures. |
#2 |
#3 |
I did some exercises for you. This might be a good start: one is an isobarik (w/two subs) and 63L (using the 2x31.5L), check the blue line; another is a double enclosure (1x31.5L), one sub with passive radiator (green line), this for one box and I used here the XLS-269-S265 with 265gr. http://www.bmm-electronics.com/Produ...roduct_ID=3341 (note that PRs are not optimized or calculated for optimum size and weight, were just introduced on WinISD software. Protect under 18Hz for max. cone excursion in both cases) |
#4 | ||||||
b 1(2) |
#5 |
2(2)
#6 | |
I suspect the intention is a Q=2 high pass filter @ 25Hz.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#7 |
Well.... That sucked.
That explains why I've never seen this driver in such a small box before... Well... Even if it's against all reason..., and the executives at Peerless will turn in their beds; I'll try. The only thing I'm loosing is some boxes that seems to turn out better than anything I've ever made before... And the work involved... (but hey; its fun though!). And maybe, some day; I might find some drivers who will acctually enjoy the somwhat tight enviroment..., and someday I might not give a crap about the size and make them big enough to make the drivers really play like they want to. Thanx for providing me with this information. I have never really understood most of the T/S parameters..., but I'm really trying Anyway; I'll keep posting pictures while I'm working.., so please continue to read this post and please ignore the foolishness of making a box not suited at all. Thanks! |
#8 | |
(I might also add that I bought the drivers some time ago..., but they are just laying here... And I've got the amps.., so why not give it a try?) |
#9 | ||
#10 |
Am i completely wrong assuming the Peerless XLS driver would love 30liters and a PR with a slightly increased mass?
If not; maybe I should get myself a couple of XLS instead of XXLS. I thought they were quite similar... but obviously not.... |
| Charcoal "Supreem" hi-density foam "enclosure" | IG81 | Multi-Way | 0 | 23rd April 2009 01:34 PM |
| Enclosure - 10" Peerless XXLS | Guy Incognito | Subwoofers | 4 | 23rd November 2007 07:50 AM |
| 8" Subwoofer Enclosure Part 2 (with thiele-small now) | hernanstafe | Subwoofers | 10 | 7th February 2007 02:45 AM |
| Dual Peerless 12" XLS in 60L enclosure | muhy3 | Subwoofers | 5 | 12th January 2005 07:45 PM |
| Enclosure for a Peerless XLS10 needed. | Kram | Multi-Way | 57 | 6th April 2004 04:03 PM |
| Page generated in 0.18987 seconds (66.07% PHP - 33.93% MySQL) with 11 queries |
