p315ho amp and lambda 15 don't like eachother, now what?
Old 17th April 2008, 01:14 AM   #1
Dejavous is offline Dejavous  United States
Default p315ho amp and lambda 15 don't like eachother, now what?
Broswing craigslist the other day I ran across a diy sub someone built based on a Lambda 15001-pfphn-4af 15" driver with a complimentary 15" passive radiator on the back. Supposedly built to specs given by the old owner of lambda for nice flat response down to around 22hz or so in the proper volume cabinet.
(I haven't measured the cab yet to give specs to verify that nor do I know enough yet to know how to even use those programs.)
The plate amp I've had for years that has served me very well with a basic 12" ACI SV12 is a Carver Sunfire 500w clone built by Acoustic Research from a P315HO speaker. (same as AR1 basically) It seems to have a boost built in for the lowest range as many or most do and I have no schematic to know how to fix it.
The boost was never an issue with the old sub, it sure is with the new one though.
I was lured into buying the new sub because my old 12 blew up, and I'd always wanted more and better anyway. I had thought of building a simple sonosub for a long time but this sub is nicer looking than what I would have come up with going that route.
What would you all reccomend I do? Keep the sub, sell the amp? Keep the amp, ditch the sub? Sell em both and do my own work with new stuff? Try to buy a schematic from AR and figure out how to disable the boost? Which sub or which amp would be worth moving up to? I couldn't afford another 500W amp this nice I don't think, nor could I build a sub like this anywhere close to what I paid for this one even I did just use sonotube.
I'm sort of stuck in a dilema, I like them both but I don't know if it's even possible to buy a schematic from AR and if I did find one I'd still need help figuring out what to do, though I can solder...
Pics of the sub attached to aid in the decision, I think it's worth keeping the sub even though it's old.
Help please?
File Type: jpg 010104011614010303200804158159310710052e44ed004c21.jpg (5.5 KB, 111 views)
Old 17th April 2008, 01:15 AM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
If you can't get the schematic you can always try adding insulation to the cabinet and adding weight to the passive cone. Neither is a perfect solution but might help with the boominess.
planet10 needs your help:
Let's help Ruth and Dave
Old 17th April 2008, 05:25 AM   #3
thank you Cal
The old owner says it's already stuffed, and that adding weight to the PR would just tune it lower and might not actually be the problem.
He's thinking maybe my receiver needs me to dig around in the on screen stuff and see if something is set wrong. (That may be, it's been over a year since the old sub died and I haven't looked in the on screen stuff since HDTV came) The receiver is a HK avr510 and only handles svideo, so not much point in hooking that up other than to look in the settings. The front panel says it's set to L/R & LFE and only gives that option or LFE or none, but maybe there's more hidden in the on screen stuff.
Boy would I be happy if that's all it takes.
Now to find an svideo cable...
Troy
Old 17th April 2008, 05:25 AM   #4
As long as I'm here where people really know about this stuff..
Does anyone know how this would compare to a pair of Elemental 13ov.2's, the ones on sale? Not looking for car audio boom but just good kick, more than on 12 could ever do for HT while still being very musical and accurate.
Have things changed enough over the past few years to make this driver less attractive for my needs than a pair of those?
thanks again
Old 23rd April 2008, 03:45 AM   #5
Nevermind, It was just the receiver that had bass boosted.
Great, my first post and I announce I'm an idiot. Welcome to the forum right?
p315ho amp and lambda 15 don't like eachother, now what?Hide this!Advertise here!
P315HO Subwoofer amp Jimmy154 Swap Meet 2 29th June 2009 02:17 PM
Best alternative to Lambda 12 Defo Multi-Way 14 10th May 2009 08:06 PM
AR P315HO down-converter adjustment Xmitr Subwoofers 1 1st January 2009 10:15 PM
Sub for Lambda PMD17K100 Grumpy_G Pass Labs 2 7th January 2006 08:49 PM
lambda dipoles jonk Multi-Way 1 6th March 2003 05:04 PM
Copyright ©1999-2017 diyAudio
