Noob needing sub for gigs.
Old 7th May 2008, 09:57 AM   #21
djk is offline djk
djk's Avatar
Since you live in the USA you should consider this $65 driver.
With freight four of these should run you about $300.
A pair per side will displace more air than most $400 pro sound 18" drivers, and as a solid 4R load they are a good match for the kind of amplifiers you should be looking at (I would look at the Tapco J1400).
Read this thread to get an idea of what the boxes should look like (anything is OK if the net volume and port size are correct), you could make them a bit smaller (and give up some of that lovely bass).
http://speakerplans.com/forum/forum_...14684&KW=%2465
Start off with two cabinets (four drivers), one amp. Double up when you can afford it.
Candidates for the Darwin Award should not read this author.
Noob needing sub for gigs.Hide this!Advertise here!
Car Battery Amp for gigs dintymoore Instruments and Amps 12 30th September 2008 10:55 PM
PCB design for TDA1541 - noob needing tips Painkiller Digital Line Level 0 3rd May 2008 10:06 AM
Which type of combo amp for live gigs: congas, bongos, cymbals, etc. Senor Tuco Instruments and Amps 3 12th May 2006 02:20 PM
Noob - Needing help deciding what Gainclone design to use tsnyder41 Chip Amps 5 19th May 2003 11:54 PM
Copyright ©1999-2017 diyAudio
