Old 13th April 2008, 09:33 AM   #1
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Default Enclosure for DD2512a
Hi
I will have to build enclosure for Digital Designs 2512a. I will try to build one from DD site. As they say sub takes about 6L of space. Box would be made from 19mm(0.75in) MDF. I would go for 50cm x 50cm for top and bottom side, this will be base for everything else(green ones on page). Left and right sides(yellow) would be 50cm x 32cm. Back side 46.2cm x 32cm. Front(red) 39cm x 32cm, with hole= 29cm, 5cm from each side of the board.
Port(red) is 32cm x 32cm, which makes 7.2cm x 39cm x 32cm high port.
Is that ok?
I ask this because box should have about 60L or 2.25^ft, but I calculated only 47L, without port...Should I add port volume as part of box volume that sub uses? If I do that I get to 56L, that is ok, right?
Should I change anything or... comments are most wellcome
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 13th April 2008, 09:40 PM   #2
Thawach is offline Thawach  Thailand
Thawach's Avatar
luka u can use 47-60 litre. i think 56 litre is o..o...che!/
Old 14th April 2008, 07:42 PM   #3
luka's Avatar
Hi
Today I went to get wood and other things, now box is build, everything now that it needs is hole for speaker and one small one for connection to amp... pictures soon
I FEEL SLOVENIA
Old 15th April 2008, 10:27 AM   #4
Thawach's Avatar
luka good luck for your build./
Old 15th April 2008, 07:15 PM   #5
luka's Avatar
Hi
Box is build, speaker is in and it gets loud as hell, I would say over 140dB...New week I will be able use meter it...Will see then...
Never heard one 12" speaker to be loud as this and this one is only medium class
I FEEL SLOVENIA
Old 25th April 2008, 02:20 PM   #6
luka's Avatar
Hi
Just to let you know what was already done...now I glued all but top board...box is super strong, as is the bass comming out of it...enough to shake everything apart
Few more to screw
I FEEL SLOVENIA
Old 27th April 2008, 09:07 AM   #7
Thawach's Avatar
luka u use a lot the screw. i count it has 33 hole. 31 holes have the screws. u forgot to put it 2 hole. luka please u try to take the pics. i wong the beautiful pics because my program have a filter, it only want the beautiful pics to copy. it iks nok like a bad pic.(sorry my voice iks nok clear because my mom iks china)
thanks/
Old 27th April 2008, 09:31 AM   #8
luka's Avatar
Hi
There are 33 of 35 screws on top, 2 are not there because there were too long. There are another 35 from bottom + 4x 5 that hold each side together, so that is 88 of 90 screws total
That you want? To send you original pics?
You should be able to see all of them ...
I FEEL SLOVENIA
Old 27th April 2008, 10:05 AM   #9
Thawach's Avatar
No i wong the box iks acting like some super model on magazine.LOL
very thanks for your reply/
Old 27th April 2008, 10:27 AM   #10
luka's Avatar
Hi
Loooool don't tell me that you like it so much?? I didn't even finnished it yet, should at the end look like it was/should be part of trunk that it is in . But thank you very much... I have to say it came out pretty good if I tell you that I did only hand drawing from top (1/10 scale) to get size of sides, so I could buy them, everything else was done pretty much as it was build, about 5-8 working hours later this came out... I just wanted to build it as fast as possible, to hear the sound of speaker... First test, about 30s from when I started car, turned on headunit and selected some song from USB, sound came out and I was left . All other speakers before that I heared were nothing compared to this.
I FEEL SLOVENIA
Switching car audio enclosure to home enclosure wattz Subwoofers 10 18th April 2010 05:51 PM
Convert horn enclosure to sub enclosure chipco3434 Subwoofers 5 22nd December 2004 03:54 PM
FS: enclosure for pre-amp jrsun Swap Meet 0 27th April 2004 02:50 PM
Page generated in 0.20185 seconds (40.60% PHP - 59.40% MySQL) with 11 queries
