Old 30th March 2008, 02:54 PM   #1
Default Ratshack Budget Subwoofer
Hi all I thought I'd do little write up of my budget HT sub.
The drivers are the old Ratshack 15"s I picked a pair up for 35 off ebay.
I borrowed a PE tester and these arent anywhere near what the specs from RS say.
RS claimed a qts of .81 or something outlandish these are barely .40
maybe it's from use I dont know.
I plotted a sealed box with the .40 qts and a VAS of 12 and got a 4.5 cu ft box with an f3 of 35hz.
Not earth shakingly low but more than enough for HT.
The amp was scavenged from a 150w 12" KLH sub cost was 20 dollars used.
The rest was wood 3/4 Baltic Birch about 2 sheets of 4x3 ft .
Cost was about 30 including glue and screws.
The bafle is double thick 3/4 Birch. Sides are 1" MDF(The MDF came free hehe from old speaker racks.)
Total cost so far is well under 90 dollars.
Here a construction pic
Thats not the baffle thats the internal brace
Old 30th March 2008, 02:55 PM   #2
Here is the finished product
Old 30th March 2008, 02:56 PM   #3
And another
Old 30th March 2008, 02:58 PM   #4
one more
Old 30th March 2008, 03:02 PM   #5
Where did you get baltic birtch that cheap?
Old 30th March 2008, 03:04 PM   #6
Home Depot I live in Upsate Ny wood is fairly cheap here.I know when I went to NYC the prices were double from up here.
Old 30th March 2008, 04:03 PM   #7
CarlosT is offline CarlosT  United States
WOW...you certainly are frugal...
So how's it sound? Is it a sealed box? Is one of the drivers a drone? Looks like a hobo's Paradigm...
Old 30th March 2008, 04:21 PM   #8
It's sealed.No drone wired in parallel they are 8ohm drivers.
Thanks for the critique,actually it's not finished literally.
The baffle and top you are seeing are raw wood.
And I still need to countersink the woofers(I don't own a router and my 8" 2ways in another thread I did with a razor and chisel definitely not an easy task doing 2 15s.) and make a grill.
Sounds very good not too boomy with a lot of low bass for only a 150w amp.
I could compare this to any sub I've seen or heard for under 700 and they wouldnt hold a candle to this.
Sounds very accurate too listening to some old JP recordings where the bass is very subtle it does extremely well.
Old 30th March 2008, 04:35 PM   #9
ßart West-VL.'s Avatar
Great!
I happen to have four of those drivers in my garage and have been wondering what the best sub for HT would be for a long time.
Would you mind posting the measurements you made, please?
In all honesty, I think the subs should play lower for HT. But that's not important if you're happy with them the way they sound now.
Bart.
Bart
Old 30th March 2008, 06:55 PM   #10
Here's what I have on the 15" Polycone foam surround RS woofer
150 watts rms
Qes .43
.Qts .40
VAS 11.96 Cu ft
SPL 91.2 1w@1m
Xmax 4.8mm
FS 24hz
8ohms nominal impedance
DC 6.2ohms impedance
I can't find the model numer its 40-1XXXXX lol I had it somewhere
Not as bad as I was originally led these drivers to be.I had passed on pair on clearance years ago.
anyway that should be enough to design a box it was for me.
Compact budget subwoofer: vented or TL/Horn? mvangel Subwoofers 21 5th February 2009 11:21 AM
Budget Subwoofer wasted911 Subwoofers 9 9th June 2008 11:39 AM
Feedback on low budget subwoofer noodle_snacks Subwoofers 13 29th January 2007 05:53 PM
great music subwoofer on a budget ifonly Subwoofers 27 27th April 2006 08:54 PM
Page generated in 0.11230 seconds (66.24% PHP - 33.76% MySQL) with 11 queries
