What's the best bandpass design calculator What's the best bandpass design calculator - Page 2 - diyAudio
Old 1st April 2008, 11:49 AM   #11
CarlosT is offline CarlosT  United States
Originally posted by palesha
...I am using others to just crosscheck.
So you've found the accuracy to be pretty much on par for all these programs?
Old 1st April 2008, 12:33 PM   #12
palesha is offline palesha  India
Every program hv it's plus points & negative points.
AJ bandpass is not interactive.
Bassbox pro shows different matching.
But if results from bass box pro fed to winspeakerz, then they r ok.
Winspeakerz gives u 9 different graphs. u select what u like.
Bassbox pro & winspeakerz r auto as well as interactive so that we can design the box as required by us.
Then we can crosscheck with other softwares.
In Subwoofer design tool box u need more experience to design bandpass box.
But the results r almost same within 2~3%.
Old 1st April 2008, 01:28 PM   #13
FSHZ42 is offline FSHZ42  United States
FSHZ42's Avatar
palesha, could you check out this link: http://www.colomar.com/Shavano/4thorder_info.html
and let me know if it compares to the other programs you mentioned.
Thanks,
Emile
Old 1st April 2008, 02:23 PM   #14
I visited the website.
The software is a simple one.
S factor is with .1 diffrence. it is high.
The port frequency step is 5 mhz. It is too high.
If u want precise results than u hv to buy commercial version.
No lunch is free.
or else give me the speaker specs with DC resistance, Qts, Vas, Fo/Fs. & ur requirements, all at one time, i will give u the box designed along with graph.
What's the best bandpass design calculatorHide this!Advertise here!
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Copyright ©1999-2017 diyAudio
