Hornresp - Page 99 - diyAudio
Old 21st February 2010, 08:42 AM   #981
Originally Posted by NEO Dan View Post
Has anyone requested the ability to enter mms, or reverse calculate mmd from mms? That particular spec is rarely published. And although I don't have a big problem with it it would be nice to be able to enter Cms in m/newton as it would be easier to read.
Hi Dan,
Thanks for your thoughts.
If Mmd is unknown, simply double-click on the Mmd input box in edit mode and follow the prompts to enter Sd, Cms and fs values. Mms data figures given by speaker manufacturers are sometimes inaccurate, and do not apply to compression drivers in any event.
Sorry, but Cms is going to stay as m/newton, and continue to be expressed using engineering notation :-). This is the generally-accepted metric standard unit for mechanical compliance, and is the one quoted on most specification sheets. You are just going to have to learn to live with exponents :-).
Kind regards,
David
www.hornresp.net
Old 21st February 2010, 08:51 AM   #982
Originally Posted by mwmkravchenko View Post
What Hornresp does is add all the piston diameter from all the drivers into one.
Hi Mark,
Just to clarify - it is the piston areas of all the drivers that are added, not the piston diameters :-).
Kind regards,
David
www.hornresp.net
Old 21st February 2010, 06:06 PM   #983
GM is offline GM  United States
GM's Avatar
I know that it can be done in AkaBak for sure. That is one evil powerful program.
Good to know, thanks! Indeed, with what has unfortunately become a very short attention span, trying to learn it has become a very frustrating chore that I currently don't have the luxury of time for.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd February 2010, 06:37 AM   #984
Default Hornresp Version 26.20
Hi Everyone,
Hornresp Version 26.20 has just been released. Changes are:
1. When the Esc key is pressed from the Input Parameters window, the user is given the opportunity to save any record changes before exiting edit mode.
2. When a Loudspeaker Wizard parameter value is decreased by clicking the left arrow on the slider scroll bar, results are immediately updated as the value reduces from 0.10 to 0.00. The arrow no longer has to be clicked a second time for this to happen.
3. Up to four sets of Loudspeaker Wizard slider control settings can be temporarily stored and recalled. (Note that it is not necessary to display and click the memory buttons - the designated function keys can be used instead).
My thanks to brsanko, Oliver (tb46) and FlipC for highlighting the issues leading to the above changes.
A number of other code refinements have also been made to hopefully ensure that the slider controls operate correctly under all conditions.
Kind regards,
David
www.hornresp.net
Old 22nd February 2010, 06:44 AM   #985
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Dude, you rock!
PASSIONN
Old 22nd February 2010, 07:14 AM   #986
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
To enter for instance 50m/N, you can press '50E-6', which Hornresp reads without problem.
Bjrn
Old 22nd February 2010, 05:29 PM   #987
FlipC is offline FlipC  United States
SWEET!
Cant tell you how much paper the "memory" function will save me.
Old 22nd February 2010, 08:11 PM   #988
BP1Fanatic's Avatar
Originally Posted by brsanko View Post
Dude, you rock!
Yeah he does
Old 22nd February 2010, 10:12 PM   #989
djeddie is offline djeddie  United Kingdom
This may or may not have been asked before but... will there ever be a driver database facility in HR? So instead of having to find various bits of paper with TS params I can just select a driver from a list.
Excellent software btw.
Old 22nd February 2010, 11:19 PM   #990
In the Horn Loudspeaker Wizard, the arrow keys won't operate the drop down menus as in the previous version. Bug?
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Copyright 1999-2017 diyAudio
