Hornresp
Hornresp
Old 3rd February 2010, 07:25 AM   #951
David McBean is offline David McBean  Australia
Thanks everyone, for the positive response to Version 26.00 :-).
Kind regards,
David
www.hornresp.net
Old 3rd February 2010, 02:12 PM   #952
bubblersound is offline bubblersound  United States
Originally Posted by David McBean View Post
Hi Everyone,
2. Efficiency values are now exported as part of the chart data. The attached Excel screenprint shows efficiency plotted for the default record system with resonances masked.
David
Thanks for this David. For easy comparison, it even gives you an average number by selecting a range of frequencies. This is great.
Old 4th February 2010, 06:49 AM   #953
Hi bubblersound,
You're welcome. Thanks for prompting me to implement it :-).
Kind regards,
David
www.hornresp.net
Old 11th February 2010, 07:02 PM   #954
tb46 is offline tb46  United States
Default Tapped Horn_Area of Throat Chamber
Hi David,
I noticed today, that when changing the port area for a throat chamber in a tapped horn from its original value (Ap1~S2) to zero the SPL response does not change.
Could there be another "bug"? :-)
V.: 2500-100108
Oliver
Old 12th February 2010, 07:03 AM   #955
Hi Oliver,
Using your example, if you look carefully as you compare SPL Response chart results, you will see a very slight difference between Ap1 = 451 and Ap1 = 0. The two curves are not exactly superimposed.
Better still, use the Tapped Horn Wizard to view the response and then the schematic, as the Ap1 slider is moved. This will better illustrate how altering Ap1 affects the results. Note in particular that Ap1 = 0.1 is something completely different to Ap1 = 0 (in both the schematic and the response).
Hope this helps to clarify things.
Kind regards,
David
www.hornresp.net
Old 12th February 2010, 07:26 AM   #956
Default Hornresp Version 26.10
Hi Everyone,
Hornresp Version 26.10 has just been released. It incorporates Sabbelbacke’s recent suggestions, but with some extra (related) functionality added in.
Changes are:
1. A slider control can be directly set to a specified value by keying in the value and then pressing Enter while the control has the focus.
2. The initial Loudspeaker Wizard slider control settings and chart results are saved as a reference baseline.
3. A slider control can be reset to its baseline value by pressing B while the control has the focus.
4. All slider controls can be reset to their baseline values by pressing Ctrl+B.
5. A new baseline with the current slider control settings and chart results can be saved by pressing Ctrl+Alt+B.
The above functionality is documented in the Loudspeaker Wizard description in the Hornresp Help file.
Could you please let me know if you find any bugs.
Kind regards,
David
www.hornresp.net
Old 12th February 2010, 11:53 AM   #957
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Every day and in every way It's getting better and better Muhhahahhahha!
Mark
Mark
www.kravchenko-audio.com
Old 12th February 2010, 02:01 PM   #958
Default Post #954/#955 Ap1_Throat Chamber Exit Area
Hi David,
I noticed the very slight difference between blocked and normal throat chamber; but, as Ap1 is the "Tapped horn throat chamber port cross-sectional area [sq cm], this would mean that the difference between a tapped horn with normal functionality (i.e.: both front and back of the driver energizing the horn) has an almost identical output to a non-tapped horn where the back (throat) side of the driver is blocked off from the horn, and additionally enclosed in a closed small back chamber. A small sealed back-chamber should definitely impact the response, e.g.: the diaphragm displacement, etc..
This just does not sound correct to me, I guess I'm just missing something.
Oliver
Old 12th February 2010, 05:26 PM   #959
FlipC is offline FlipC  United States
David -
So is there a way to flip between settings without having to reset and redo to compare?
That is one thing I do wish HR had.
Like the Compare function but having "memory slots" (like Bass Box) so you don't have to create a duplicate, adjust it, then go back to original to compare.
Old 12th February 2010, 07:18 PM   #960
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Hi Everyone,
David,
Thanks for the new features!
Dan
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
