| Thread Tools | Search this Thread |
#941 |
Hi Ivo,
Hornresp was originally 16-bit, but was upgraded to 32-bit with the release of Version 20.00. There is no 64-bit version :-). Kind regards, David
www.hornresp.net.ms |
#942 |
Regards, Dan |
#943 |
Hi David,
wonderfull improvements As my cat just stood on the keyobard while I got coffee, a slider went up to max (999) - an idea came up: How about - if a slider in the wizard is select - pressing "0" reverts it to value zero or the default value when the wizard was entered ? Another idea: If a response was recorded in the SPL Chart, having the option to display it in the wizard could help compare two design variants of the same box. A little button maybe? Nothing big, but may be usefull in some cases and might not be too much work to implement? Thanx once again for the great job!!! |
#944 |
Thanks Dan.
Sorry, Fortran and Microsoft Visual Basic are all that I know :-) Kind regards, David
#945 | |
Thanks for the two excellent suggestions - I will keep them in mind for the future. Kind regards, David
#946 |
Doh! I meant I was using the 64-bit version of Ubuntu.
I sehs there is no stronger breastplate, than the heart that is undainted. |
#947 |
Works like a good tool should. Many thanks David.
Mark
Mark |
#948 |
Thank you very much David!
#949 |
EXCELLENT program David!
#950 |
Hi FlipC,
I have checked the Hornresp code but can’t find any reason why the TH flags should change to OD flags when the data file format is updated. Perhaps in your case, it was in some way related to the other Hornresp.dat file corruption problems you were experiencing. Kind regards, David
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
| Page generated in 0.13899 seconds (72.75% PHP - 27.25% MySQL) with 11 queries |
