Hornresp - Page 88 - diyAudio
Old 4th January 2010, 05:47 AM   #871
Originally Posted by mwmkravchenko View Post
Have to ask. Working on a bunch of front loaded horns lately. And I only wish I had the type of sliders I ask for. Make things oh so much easier.
Hi Mark,
Out of curiosity I tried adding a 3 second delay to the Tapped Horn Wizard calculation time to see what would happen. Operation of the sliders became unworkable under those conditions. In most cases Hornresp simply locked up and had to be shut down and restarted.
Note that long front-loaded hyperbolic-exponential bass horns can have calculation times exceeding 10 seconds :-).
Kind regards,
David
www.hornresp.net
Old 4th January 2010, 06:00 AM   #872
Originally Posted by FlipC View Post
So more notes on my delima.
I checked the data file.
It reads 87 KB while an old .dat file (which works) reads 16 KB.
Of course the old one only has 47 entries. When I open the .dat file it only shows info for 1 entry.
Hi FlipC,
If you care to send me copies of both your Hornresp.dat data files, I will see if I can work out what has gone wrong (and attempt to repair the corrupted file).
My email address is dmcbean@bigpond.com
Did you install the latest version of Hornresp in the same folder as before, overwriting your earlier version?
Kind regards,
David
www.hornresp.net
Old 4th January 2010, 06:02 AM   #873
Originally Posted by mashaffer View Post
That worked. I copied all of the /windows/fonts files over to the .wine/windows/fonts directory on the UNIX box and HR came up fine. Ready to R&R.
Excellent :-).
www.hornresp.net
Old 4th January 2010, 06:50 AM   #874
FlipC is offline FlipC  United States
I will email you the items.
And no. I have the .dat file. I copied it and saved it. Also I did install the new version but not over the old one just in case..
Old 4th January 2010, 07:27 AM   #875
Hi FlipC,
Got the files okay, thanks. I will reply via email.
Kind regards,
David
www.hornresp.net
Old 4th January 2010, 10:16 AM   #876
@David
Thanx once again for the very usefull extensions of hornresp. This will come in handy and are much appreciated
Old 5th January 2010, 06:57 AM   #877
Hi Sabbelbacke,
You're most welcome. Happy New Year! If you come across any bugs in Version 25.00, please don't forget to let me know :-).
I have already fixed a minor error I found in the Tapped Horn Wizard. (When the Eg slider is set to zero, the driver diaphragm should have a constant rms velocity of 10 cm/sec - this was not happening). The latest release is Product Number 2500-100105.
Kind regards,
David
www.hornresp.net
Old 5th January 2010, 11:34 PM   #878
Mark Kravchenko
mwmkravchenko's Avatar
Hi Mark,
Kind regards,
David
Thanks for trying David. At least I'm not the only one with the thought as to if it could work. Is it a question of horsepower under the hood or the programing itself. I think you are using visual basic? Not that I can help in that regard. My high level programing language was Turbo Pascal!
Could it work with conical horns? That is what we all usually end up with when we build bass horns anyway. I make a conic that approximates what ever shape is designed.
Mark
Mark
www.kravchenko-audio.com
Old 6th January 2010, 12:31 AM   #879
cowanaudio's Avatar
G'day David
Another little bug in Hornresponse to report.
I set S1 to 0 in a tapped horn design (HR 24.00) and an error message came up. After closing the error message the program hung and I could no longer change any values. Perhaps you could add a very small value to S1 to stop the error happening at all.
Cheers
William Cowan
Don't Procrastinate....Just Do It!
Old 6th January 2010, 06:25 AM   #880
Hi Mark,
It's mainly a question of processor horsepower, although inherently Visual Basic is certainly a bit slower than Pascal (which can be almost as fast as Fortran).
Yes, and with any multiple-segment system having conical and/or exponential flares.
I have no plans at the moment to do anything about it though... :-).
Tapped horns appealed to me originally because they are very sensitive to dimensional changes, making the Wizard particularly useful in this case - I was really just looking for something to test out the slider concept.
Kind regards,
David
www.hornresp.net
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright 1999-2017 diyAudio
