Hornresp - Page 81 - diyAudio
Old 21st October 2009, 10:32 PM   #801
Ivo is offline Ivo  Netherlands
I thought I posted this question, but it seems lost. Excuse me if I double posted this.
I would to combine tractrix mouth sections with other flare sections. Is that possible for a future update?
We want to be happy, bold and free
Old 22nd October 2009, 08:15 AM   #802
Originally Posted by GM View Post
but one never knows without asking.
That's so true :-).
www.hornresp.net
Old 22nd October 2009, 08:26 AM   #803
Hi Ivo,
A similar question was asked in Post #475, but by somebody else. My answer has to be the same though - because it would effectively require a complete re-build of Hornresp, it's not going to happen :-).
Kind regards,
David
www.hornresp.net
Old 22nd October 2009, 01:53 PM   #804
soongsc is online now soongsc  Taiwan
soongsc's Avatar
Originally Posted by David McBean View Post
Hi Ivo,
Kind regards,
David
Yep, I posted that request quite a while back.
Hear the real thing!
Old 22nd October 2009, 09:27 PM   #805
copy/paste approach to import/export seems practical. No need to mock about with files on forums. Simple with clean, editable format.
It could look like the printed version even. Although tab it usually not working on most forums.
Old 23rd October 2009, 08:22 AM   #806
Hi David_Web,
Thanks for your comments.
I think I now have a reasonable idea of the sort of import/export functionality users would like to see in Hornresp. I will try to come up with something that at least meets the key requirements people have identified.
Kind regards,
David
www.hornresp.net
Old 27th October 2009, 06:24 AM   #807
Default Hornresp Version 24.00
Hi Everyone,
The latest release of Hornresp can import / export files containing individual records.
An exported record is saved as a text file, and can be:
1. Transferred as an e-mail attachment from one Hornresp user to another.
2. Included as an attachment to a forum message.
3. Opened in Notepad and the text copied and pasted into the body of a forum message.
To import a record embedded as a text listing in a forum message:
1. Copy the record text from the message and then paste into Notepad and save as a text file.
2. Place the text file in the Hornresp \ Import folder.
3. Import the record using File > Import from the input parameters window.
Notes:
1. Regional number setting conversions are handled automatically - for example, a record file exported by a user in Germany can be directly imported by a user in England.
2. Because the exported record is saved as a text file, when the filename is double-clicked in Windows Explorer the file will open in Notepad rather than in Hornresp.
3. It is possible to edit the text file in Notepad, although this action is not recommended. In particular, the Version Number shown in line 1 of the listing should never be altered.
4. The HornrespMerge program may not work properly with the latest release of Hornresp.
5. A sample exported record file text listing is shown below. The file is also included as an attachment to this message.
Ver=24.00
Ang=2.0 x Pi
Eg=2.83
Rg=0.00
Fta=2.31
S1=275.00
S2=306.70
Con=13.00
F12=0.00
S2=306.70
S3=713.50
Con=128.50
F23=0.00
S3=713.50
S4=770.00
Con=14.50
F34=0.00
S4=0.00
S5=0.00
L45=0.00
F45=0.00
Sd=350.00
Bl=12.20
Cms=1.77E-04
Rms=3.22
Mmd=25.45
Le=1.20
Re=5.10
TH=1
Vrc=0.00
Lrc=0.00
Ap1=0.00
Lpt=0.00
Vtc=0.00
Atc=0.00
Com=William Cowan 60 hertz tapped horn with Eighteen Sound 10W400 driver
Please let me know if you find any bugs in the latest release.
Kind regards,
David
File Type: txt example.txt (435 Bytes, 33 views)
www.hornresp.net
Old 27th October 2009, 06:49 AM   #808
Hi Everyone,
For some reason I am experiencing difficulties downloading a copy of the example.txt file attached to the previous message. Does anyone else have the same problem?
Is this a forum bug, perhaps?
Kind regards,
David
www.hornresp.net
Old 27th October 2009, 09:03 AM   #809
Jmmlc is offline Jmmlc  France
R.I.P.
Hello david,
I could download the text file attached to your message (example.txt) and import it successfully in Hornresp.
This import function is a great new feature for the Hornresp users.
Thanks a lot.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Hi Everyone,
Kind regards,
David
Old 27th October 2009, 09:48 AM   #810
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
great new feature, thanks a lot!
btw: I could download the attachment without any problems
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2017 diyAudio
