Hornresp
Hornresp
Old 10th October 2017, 04:02 PM   #7901
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
+1!
Old 12th October 2017, 03:16 PM   #7902
screamersusa is offline screamersusa  United States
Default Finding Rms rating??
Im not sure where to find or calculate the Rms field, mechanical resistance.
Could someone explain how to calculate it?
Also is there a table somewhere that lists the different names that some parameters are named. I vaguely remember that there were at least two parameters that different manufacturers use different names for.
Cheers
Old 13th October 2017, 12:38 AM   #7903
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Cheers
Thiele/Small parameters - Wikipedia
Mark
www.kravchenko-audio.com
Old 13th October 2017, 01:43 AM   #7904
just a guy is offline just a guy  Canada
Hornresp will calculate it for you. Double click the Rms input box and a wizard will help you, allowing you to enter Fa and Qms instead of Rms and Hornresp will sort out the rest.
Most of the input boxes have wizards to help you and there's always handy info about the input box at the bottom of the Hornresp window if you hover your mouse over the box.
Old 13th October 2017, 08:34 AM   #7905
David McBean is offline David McBean  Australia
Alternatively, double-click on the Sd input box in Edit mode to enter all the driver parameters in the one operation, using Thiele-Small values.
www.hornresp.net
Old 13th October 2017, 02:39 PM   #7906
I thought there was a way for it to calculate that value but it's been a few years since I designed any cabs and I've never tried to do a vented box in it.
Amnesia..... duh
Old 20th October 2017, 08:49 PM   #7907
freddi is offline freddi  United States
freddi's Avatar
Hornresp
problem - can't remember how to invoke the "ABC" cabinet function - - also could not get a 2nd order active highpass with Q = 2 to work (my version = 42.40)
Old 21st October 2017, 07:48 AM   #7908
Hi freddi,
In edit mode, with the Ctrl key pressed, double-click on the Nd label to step through the ME1, ME2, BP6, BP8, ABC driver arrangement options. Alternatively, select the Tools > Driver Arrangement menu and choose Aperiodic Bi-Chamber ABC from the drop down Arrangement list.
It's all in the Hornresp Help file - simply use the File > Find menu (in the Help file) to search for ABC.
Many thanks for this feedback. The second and fourth order active filters appear to be working okay in the filter tool charts themselves, but not in the main charts. I will investigate.
Kind regards,
David
www.hornresp.net
Old 22nd October 2017, 06:57 AM   #7909
I should have also mentioned that another way to specify an ABC system is simply to create a new record using the Input Wizard tool, located under the Help menu.
www.hornresp.net
Old 22nd October 2017, 07:09 AM   #7910
Default Hornresp Update 4240-171022
Hi Everyone,
BUG FIX
The bug reported by freddi in Post #7907 has now been fixed.
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
