Hornresp
Hornresp
Old 17th September 2017, 03:45 PM   #7871
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Originally Posted by Orion33 View Post
Yes, I want to try. But what?
These are examples of exponential subwoofer horns. If you are not building something similar, then you need to be modeling a parabolic enclosure.
Old 18th September 2017, 06:05 AM   #7872
David McBean is offline David McBean  Australia
The second example appears to be a tractrix or spherical wave horn - the mouth flare tangent angle is close to 90 degrees.
Just to clarify, the above statement only applies to horns with two parallel sides - in which case the system needs to be modelled using multiple parabolic segments to approximate the desired overall exponential profile (see attachment). A single-segment parabolic horn would not be a good design choice for a bass system :-).
www.hornresp.net
Old 18th September 2017, 02:35 PM   #7873
BP1Fanatic's Avatar
The pic was to show that all sides expand in an exponential horn whether round or square. Here is a better example for a round exponential horn.
Old 18th September 2017, 03:45 PM   #7874
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Kinda looks like a conical horn there buddy
Mark
www.kravchenko-audio.com
Old 19th September 2017, 06:50 AM   #7875
More like a conical megaphone - complete with handle. A bit small to be used as a subwoofer, though :-).
www.hornresp.net
Old 19th September 2017, 02:14 PM   #7876
BP1Fanatic's Avatar
My mistake!
Old 21st September 2017, 12:23 PM   #7877
Orion33 is offline Orion33  Russian Federation
A little offtopic.
Can anybody provide files to calculate the horn from here: Quarter Wavelength Loudspeaker Design ?
Old 21st September 2017, 02:55 PM   #7878
Mark Kravchenko
Hornresp
A little offtopic.
The math between the two programs either Martin's work or David's work should be very similar if not the same.
At least for the horn design and specification side of things.
Are you looking for the mathematical derivation of a particular horn type?
Mark
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2017 diyAudio
