Hornresp
Hornresp
Old 5th October 2009, 09:12 PM   #771
Don Hills is offline Don Hills  New Zealand
Originally Posted by David_Web View Post
So there is a workaround? Sweet, that always bugged me about AkAbak.
It still won't do straight segments right? Could probably be replaced with ducts then. Or a very small taper.
Lots of IF and AND statements I guess :-)
The famously impenetrable AkAbak manual describes how to do decreasing section waveguides. First two paragraphs, top of page 194, in the description of the Waveguide component.
As you say, waveguides with throat size = mouth size have to be represented by ducts.
Old 6th October 2009, 09:27 AM   #772
David McBean is offline David McBean  Australia
Originally Posted by David McBean View Post
I am pretty busy at the moment, so it may take a few days, but I will let everyone know once it is done.
Hi Don,
I have just discovered that AkAbak predicts results different to those calculated by Hornresp for negative flare horns. I need to investigate further. It seems that it may now take me more than "a few days", before I can release anything :-).
Kind regards,
David
www.hornresp.net
Old 7th October 2009, 08:27 AM   #773
Default Hornresp Update
Hi Don / Everyone,
Just letting you know that Hornresp now exports AkAbak scripts for both positive and negative flare horn segments. Product Number 2320-091007 refers. Hornresp and AkAbak predictions are identical.
Kind regards,
David
www.hornresp.net
Old 7th October 2009, 01:12 PM   #774
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
now there's some good help AND some good news on 1 page! thanks lads
Old 7th October 2009, 01:15 PM   #775
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Default Thumbs up!
Thanks David!
This makes working in AkaBak so much easier. I just did an export of my funny bowtie horns and it works perfectly. It also simulates fairly similarly. Not exactly the same. My guess is that being able to excite the horn from different locations with movable driver points is what makes the greatest difference.
Mark
Mark
www.kravchenko-audio.com
Old 8th October 2009, 02:01 AM   #776
Hi Mark,
For a single-driver system, the un-combined power response, electrical impedance and diaphragm displacement results should be identical.
The AkAbak pressure response will be different from the Hornresp power response.
Kind regards,
David
www.hornresp.net
Old 8th October 2009, 02:46 AM   #777
Hi Mark,
I should have perhaps clarified that identical results require that the Hornresp chamber resonances are not masked, and that the AkAbak settings are as detailed in the header to the exported script.
Kind regards,
David
www.hornresp.net
Old 8th October 2009, 03:18 AM   #778
Mark Kravchenko
Hornresp
Hi David
I'm still in the process of changing over an existing box into a new fold. So I will carefully measure what comes of the changes and report back.
Mark
Mark
Old 14th October 2009, 07:07 AM   #779
Default Hornresp Version 23.30
Hi Everyone,
Hornresp can now export SPL and Ze data in files suitable for direct importation into loudspeaker design tools such as LEAP, Boxsim, SoundEasy, CrossoverShop, etc.
All calculated results can still also be exported using the standard *.txt or *.csv bulk data files.
Kind regards,
David
www.hornresp.net
Old 14th October 2009, 05:38 PM   #780
Mark Kravchenko
Hornresp
Now we are getting into some serious capabilities. Muchly appreciated David.
Mark
Mark
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
