Hornresp
Hornresp
Old 3rd August 2009, 06:32 AM   #721
David McBean is offline David McBean  Australia
Hi sumsound,
Originally posted by sumsound
It would be pretty odd to have an amplifier that delivers constant wattage to any load.
So true :-).
Is there a way to see what maximum output is for constant voltage, with respect to xmax?
Calculate the results for a given value of Eg and then check the Diaphragm Displacement chart to see if the excursion has exceeded the Xmax value for the driver you have specified. After a few iterations using different values of Eg you should be able to find the maximum constant voltage that can be applied to the loudspeaker without exceeding Xmax at any frequency.
Remember though, in practice a normal audio signal voltage will not be constant at all frequencies :-).
Kind regards,
David
www.hornresp.net
Old 30th August 2009, 05:50 AM   #722
Default Hornresp Version 23.10
Hi Everyone,
Hornresp Version 23.10 has just been released. Product Number 2310-090830 refers.
The Horn Segment Wizard tool can now also be used with Le Cléac'h horn designs.
Kind regards,
David
www.hornresp.net
Old 30th August 2009, 06:49 AM   #723
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Great! I've been wanting to try out some low frequency horn designs.
Hear the real thing!
Old 30th August 2009, 11:21 AM   #724
David_Web is offline David_Web  Sweden
Any chance that we will be able to change Q of the port/vent in the future?
Basta! does this and you can then simulate an "aperiodic" box.
But you can't add a horn in Basta!.
You can find it here in case you haven't seen it. http://www.tolvan.com/basta/
Old 1st September 2009, 06:11 AM   #725
Hi David_Web,
It is highly unlikely.
Kind regards,
David
www.hornresp.net
Old 23rd September 2009, 06:24 PM   #726
tb46 is offline tb46  United States
Default Compound Horn?
Hi David,
The other night I was playing around with the compound horn arrangement, trying to use it for something (think Altec 816) with: 1. short exponential front horn, 2. large vented rear chamber, 3. short exponential rear horn (used as reflex port). This seemed to model just fine (well, the response may well be too fine :-)). Looking a little closer I found the following:
- there is a point where reducing Area S2 (front horn mouth) by as little as 1cm^2 markedly affects the low end, and
- the same thing happens when reducing Area S6 (rear horn mouth) from the input screen value shown.
I'll attach the input screen for your information. It would be great if the compound horn arrangement could be used reliably for cases like this one.
Thought you might find this interesting.
Oliver
Old 24th September 2009, 06:08 AM   #727
Hi Oliver,
Many thanks - I certainly do find it interesting!
When I first calculate the combined response for your example, I get a particular result. If I then calculate the combined response again (without changing anything) I get a different result - see attached comparison. There is definitely a bug somewhere :-).
I will investigate over the next few days, and let you know what I find.
Kind regards,
David
www.hornresp.net
Old 24th September 2009, 08:27 AM   #728
Hi Oliver,
Just letting you know that the bug you reported has been fixed - it only took one keystroke to rectify :-). I had been using a variable named S2 in a formula when I should have in fact been using S22 (a typographical error on my part). Unfortunately the combined response for your example is now not as impressive as it once was :-).
Thanks again for bring this bug to my attention - it was causing quite a serious error in the results!
The corrected Hornresp release is Product Number 2310-090924.
Kind regards,
David
www.hornresp.net
Old 24th September 2009, 01:56 PM   #729
Smile Post #728, Compound Horn
Hi David,
Thanks for getting to this problem as quickly as you did. I'm happy you were able to find an easy to fix cause.
I did not believe the impressive low frequency output :-), that's what got me to look at it a little closer. The data I'm getting now looks a lot more real, still quite nice though. I'm also having a bit of a problem with a simulation of the Lowther TP1 London, but I'm still extracting data from the drawing. I'll post it as soon as I have something.
Thanks again for the quick response,
Oliver
Old 24th September 2009, 02:39 PM   #730
Rademakers is offline Rademakers  Netherlands
Hi David,
Is it possible that, after you've typed the length in L12 (etc.) the horn flare automatically adjusts to, say conical, instead of requiring the push of that extra button, (like C, H or E) that I regulairy forget?
I know, I know but it just keeps on happening (and resetting)
Best regards Johan
Impossibilities we do immediatly, miracles take slightly longer.
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
