Hornresp
Hornresp
Old 20th July 2009, 02:56 AM   #711
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Default Hello David
Has anybody asked for a means to incorporate resistive dampening in a tapped horn ala fibrous batting or the like. I remember a couple of articles away back in the JAES about measured effects of fibrous tangles and sound transmission. If I remember correctly there was a great deal of math several kilometers above my head level.
Mark
Mark
www.kravchenko-audio.com
Old 20th July 2009, 08:20 AM   #712
David McBean is offline David McBean  Australia
Default Re: Importing / Exporting Individual designs
Originally posted by zobsky
Is there a way to export / import particular designs to a portable format? I've always thought this would be a useful feature, especially for the purpose of presenting various designs on this board for critique.
Hi zobsky,
Most Hornresp users simply post a screenprint of the Input Parameters window when they wish to present a design.
Designs can be exported to AkAbak, but I have no plans to enhance the export feature or to provide an import function.
Kind regards,
David
www.hornresp.net
Old 20th July 2009, 08:35 AM   #713
Default Re: Hello David
Hi Mark,
Try using AkAbak.
Kind regards,
David
www.hornresp.net
Old 20th July 2009, 08:50 PM   #714
zobsky is offline zobsky  India
zobsky's Avatar
Default Re: Re: Importing / Exporting Individual designs
Originally posted by David McBean
Hi zobsky,
David
Thanks, .. that's what I currently do
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 21st July 2009, 08:38 AM   #715
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Default Re: Re: Hello David
Try using AkAbak.
klick-e-ree-klick
Old 1st August 2009, 08:10 PM   #716
sumsound is offline sumsound  United States
Hey David,
I was playing with the maximum output feature, and I have a feeling it doesn't work quite right.
If I put in 1Watt with a 13mm xmax, the result is far from expected. Everything starts looking strange.
Old 2nd August 2009, 04:47 AM   #717
fb is offline fb  Australia
David, could we please get a slightly higher contrast for the minor SPL divisions in the graphs - It might just be my monitor, but it's a bit hard to see when designing bass horns
Old 2nd August 2009, 07:36 AM   #718
Hi sumsound,
As detailed on page 12 of the Hornresp Help file, the Maximum SPL tool displays the maximum sound pressure level in decibels that can be achieved at 1 metre without exceeding the rated thermal limited electrical input power Pmax or the diaphragm linear mean-to-peak displacement limit Xmax, versus frequency in hertz.
In the example you have quoted the electrical input power is fixed at 1 watt, independent of frequency. You have effectively specified a constant power source - which is quite different to the constant voltage source normally assumed by the program. With a constant voltage source the electrical input power can vary significantly as the load impedance changes with frequency.
To illustrate - with your example try using the Sample tool on your original grey constant voltage source SPL response result to check the value of the electrical input power at 65 hertz. You will find that it is somewhat less than 1 watt.
This is the reason why your response "looks strange". I am pretty sure you will find that the Maximum SPL tool is working correctly :-).
Kind regards,
David
www.hornresp.net
Old 2nd August 2009, 07:52 AM   #719
Originally posted by fb
Could we please get a slightly higher contrast for the minor SPL divisions in the graphs - It might just be my monitor, but it's a bit hard to see when designing bass horns.
Hi fb,
It's either your monitor or the Windows colour scheme you are using :-). As you can see from sumsoundís screenprint above, the minor gridlines are normally quite visible. If all else fails when in doubt the Sample tool can be used to check results at specific frequencies.
Kind regards,
David
www.hornresp.net
Old 2nd August 2009, 09:18 AM   #720
Hi sumsound,
Kind regards,
David
Duh that makes an awful lot of sense,
Since a speakers impedance changes with frequency.
It would be pretty odd to have an amplifier that delivers constant wattage to any load.
Thanks-
I guess I'll have to read the manual more, is there a way to see what maximum output is for constant voltage, with respect to xmax?
Or will I have to do the math to spot check???
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
