Hornresp
Hornresp
Old 9th January 2017, 10:50 AM   #6961
CUTTING EDGE CNC is offline CUTTING EDGE CNC  United Kingdom
Thanks for the links, the latter I have viewed. From looking at the various horn configurations, I thought the design was most closely represented by the offset horn. But as your first link defines trapped horn as those that have the driver part way along a horn segment I guess this also applies to the design.
Old 9th January 2017, 11:13 AM   #6962
Originally Posted by David McBean View Post
Hi CUTTING EDGE CNC,
A possible alternative model could be as shown in the attachments.
Kind regards,
David
EDIT - Use the Loudspeaker Wizard to add the necessary absorbent filling material to the transmission line.
Thanks very much David. I have attached an edited drawing showing the dimensions of a section 3.8cmx10cm and 1.2cm long. Could you please let me know if this should be represented as a horn segment or not. and if so, if there are more than 4 segments, how is the data entered?
On a side note, after reading the recent comments on this thread it must be irritating and disheartening for you to have to put up with pedants. It's one thing for a user to point out a potential glitch to aid the development of the software, but to criticise in such a pius fashion is offensive.
Old 9th January 2017, 03:23 PM   #6963
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
b
Old 9th January 2017, 03:40 PM   #6964
Bjorno, Thanks for taking the time to provide me this info....you're a top man. Your TABAQ's are very close to what I would like to make, and so using them as a starting point is huge help.
Old 10th January 2017, 06:23 AM   #6965
David McBean is offline David McBean  Australia
Ideally the 3.8cm x 10cm x 1.2cm duct volume should be modelled as a separate segment, however because Hornresp is limited to four segments it is necessary to make a simplifying assumption, as bjorno has done.
In my example I simply used your 10.2cm figure for the final segment length without checking the dimensions on the drawing. Somewhere around 14 cm would appear to be a more accurate figure to use, as shown by bjorno.
Kind regards,
David
www.hornresp.net
Old 10th January 2017, 06:36 AM   #6966
Just to clarify, the design in question is a mass-loaded transmission line loudspeaker, and should be modelled in Hornresp as an offset driver (OD) system, not a tapped horn (TH or TH1) system.
www.hornresp.net
Old 10th January 2017, 11:04 PM   #6967
Zero D is offline Zero D  United Kingdom
Question Polarity ?
@ David McBean CodeMaster
Hi, even with the latest version i've searched right through the HLP file, & cannot find how to reverse the polarity of a driver ! Apart from where it mentions it in the Wavefront Simulator, but i want to be able to do it generally.
Am i going blind, or ?
Rice Kellog still going strong Not sent from a SpyPhone with CrapApps etc
Old 11th January 2017, 06:11 AM   #6968
Hi Zero D,
The polarity of a source / driver can be reversed in the Wavefront Simulator tool and in the Multiple Entry Horn Wizard, but not generally.
If you are seeking to reverse the polarity of selected drivers in either a multiple driver or a multiple speaker array, then for the results to be meaningful it would be necessary for the Hornresp simulation model to take into account the relative geometric positions of each of the multiple drivers or speakers in the array. This would require additional input data values, and would complicate things enormously.
Another one for AkAbak, it seems.
Kind regards,
David
www.hornresp.net
Old 11th January 2017, 11:07 PM   #6969
I would be very grateful if someone could take a look at the attached section drawing and let me know if I have entered dims into the hornresp parameters correctly.
Old 12th January 2017, 01:13 AM   #6970
mwmkravchenko is online now mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
From your drawing I get a total center line length of 83.3cm. And a port length again by center line of 6.4 cm
Your simulation as setup is a length of 85.2 cm and a port length of 6 cm.
Have you looked at the response of the simulation?
Mark
www.kravchenko-audio.com
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
