Hornresp - Page 69 - diyAudio
Old 3rd July 2009, 09:31 AM   #681
Default Re: Re: HORNRESP VERSION 23.00
Hi Jean-Michel,
Originally posted by Jmmlc
The delay tool added to the phase response chart is very efficient and very useful.
Excellent.
Thanks for the throat impedance improvement of the Le Cléac'h horn.
You're welcome.
BTW: on the phase graph may be the tics marks should be put every 45°...
I will see what I can do :-).
Kind regards,
David
www.hornresp.net
Old 4th July 2009, 07:12 AM   #682
Hi thend, Jean-Michel and gtphill,
Contrary to my earlier advice in Post #674, I have now managed to establish through further testing and analysis that the wavefront simulator problem reported by thend is in fact not triggered by the model breaking down when the wavefronts reach the boundary of the sound field grid.
After a thorough checking of the code, I have no idea what is causing the strange results - perhaps they are being generated by some kind of aliasing effect. It is interesting that the problem does not occur in all cases - it seems to depend on the test frequency chosen.
Another one of GM’s "life’s little mysteries", perhaps... :-).
Kind regards,
David
www.hornresp.net
Old 4th July 2009, 07:15 AM   #683
Hi Jean-Michel,
The phase response chart y-axis scale increment has been reduced from 100 degrees to 45 degrees, as suggested. Product Number 2300-090704 refers.
Kind regards,
David
www.hornresp.net
Old 4th July 2009, 09:09 AM   #684
This is becoming tiresome.
I am having to download a better, more comprehensive version of Hornresp every week.
When are the improvements going to stop?
David,
Thank you.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th July 2009, 02:58 PM   #685
Jmmlc is offline Jmmlc  France
R.I.P.
Default Re: Re: Re: HORNRESP VERSION 23.00
Hello David,
Thanks, the analysis of the phase curve is now easier withe the 45 degrees tics marks.
One thing I noticed thoughis that, the test of the phase polarity I used to insert in the phase unwrapping seems now inefficient.
Please give a look to the attached graph. You'll see that on a very wide interval of frequency the phase is near of -180degrees or +180degrees. In such case, normally the polarity check introduce a 180 degrees shift in order to have the phase evolving around 0 degree.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Originally posted by David McBean
Hi Jean-Michel,
Kind regards,
David
Old 6th July 2009, 06:12 AM   #686
Default Re: Re: Re: Re: HORNRESP VERSION 23.00
One thing I noticed though is that, the test of the phase polarity I used to insert in the phase unwrapping seems now inefficient.
Hi Jean-Michel,
Remember, I am using:
for I = 1 : Nfreq;
PUNW(I) = PUNW(I) - Dphase * FREQ(I);
end
rather than:
for I = 1 : Nfreq;
PUNW(I) = PUNW(I) - Dphase * (FREQ(I) - FREQ(1));
end
Could this be the reason for the "inefficiency", perhaps?
Also, could you please post a screenprint of the input parameters you used to produce the phase response shown in your graph.
Did you use the default delay calculated by the program, or a different value entered with the Delay tool?
Kind regards,
David
www.hornresp.net
Old 6th July 2009, 06:40 AM   #687
Hi Andrew,
Just found and fixed another two bugs - Product Number is now 2300-090706 :-).
Kind regards,
David
www.hornresp.net
Old 6th July 2009, 10:25 AM   #688
R.I.P.
Default Re: Re: Re: Re: Re: HORNRESP VERSION 23.00
Hello David,
The last phase curve was the one obtained when running Hornresp on that example:
http://www.diyaudio.com/forums/attac...amp=1242139718
The "polarity check" in Matlab language is as such:
S1 = 0.0; S2=0.0;
for I = Imag1 : Imag2;
S1=S1+(PUNW(I)^2); S2=S2+(abs(PUNW(I))-2.3562)^2;
end
if S2>S1;
for I = 1 : Nfreq;
PUNW(I) = PHASE(I)- Dphase*FREQ(I);
PUNW(I)=PUNW(I)-2*pi*fix(0.5+(PUNW(I)/2/pi));
end
else
for I = 1 : Nfreq;
PUNW(I) = pi+( PHASE(I)- Dphase*FREQ(I));
end
end
All angle values in those lines of code are in radians (even the value 2.3562 which is 3/4 Pi radians and should be replaced by 270 if your own Visual Basic code uses degrees for angle values .
It only should be performed one time only (for the default "modified phase curve"), then when using the "added delay tool" it should not be done anymore.
You'll find in attached file the same phase curve as obtained using my Matlab code.
Hi Jean-Michel,
for I = 1 : Nfreq;
end
rather than:
for I = 1 : Nfreq;
end
Kind regards,
David
Old 7th July 2009, 09:46 AM   #689
R.I.P.
Default Re: Re: Re: Re: Re: Re: HORNRESP VERSION 23.00
Hello David,
You surely corrected my sentence (see quotation) that should be:
"All angle values in those lines of code are in radians (even the value 2.3562 which is 3/4 Pi radians and should be replaced by 135 if your own Visual Basic code uses degrees for angle values ."
Old 8th July 2009, 07:09 AM   #690
Hi Jean-Michel,
I had been using the original code you sent me:
% set phase between -pi and +pi for graph output
if abs(PUNW(Imag1))<pi/2.5;
PUNW=mod(PUNW+pi, 2*pi)-pi;
else
PUNW=mod(PUNW, 2*pi)-pi;
end
I will change to the new code. Thanks.
Kind regards,
David
www.hornresp.net
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2017 diyAudio
