Hornresp
Hornresp
Old 19th June 2009, 06:22 AM   #621
David McBean is offline David McBean  Australia
Default HORNRESP VERSION 22.20
Hi Everyone,
Hornresp Version 22.20 has just been released. Eg can now be set to 0. A zero value for Eg means that the driver diaphragm has a constant rms velocity of 10 centimetres per second (option suggested by Jean-Michel).
Product Number 2220-090619 refers.
Kind regards,
David
www.hornresp.net
Old 19th June 2009, 09:26 AM   #622
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
wow, you keep putting out new versions faster than I drink coffee (well, almost ) Thanks a lot!
maybe it was already asked somewhere in the previous 25 pages, but would it be possible if the number of segments is variable and the input sheet adjusted accordingly? and have a bit more than 4 segments?
another, probably more difficult to answer question, could stuffing be added to each segment? this may not be important to the typical horn, but for the TL fraction out here this is very important.
Old 19th June 2009, 09:47 AM   #623
Henkjan's Avatar
Originally posted by David McBean
..... The volume of each segment is of course already given on the main Schematic Diagram when the mouse pointer is moved over the segment. The total system volume is also shown (see attached).
your program is full of those little gems, I love it more every day only having a brief manual and discovering features as you go has it's charmes
Old 19th June 2009, 11:14 AM   #624
Jmmlc is offline Jmmlc  France
R.I.P.
Default Re: HORNRESP VERSION 22.20
Hello David,
Thanks a lot for all the work you do to give a solution - when possible- to such requests as mines.
The constant velocity diaphragm will be very useful to compare horns without the influence of the driver.
Here attached the response of Le Cléac'h horns having the same cut-off frequency (Fc = 160Hz) and different T values (from 0 to 1.5)
Best regards from Paris, France
Jean-Michel Le Cléac'h
Hi Everyone,
Kind regards,
David
Old 19th June 2009, 11:36 AM   #625
David_Web is offline David_Web  Sweden
How on earth did I miss that. Talk about absent minded
I blame it on the horns
Old 20th June 2009, 06:51 AM   #626
Originally posted by Henkjan
Maybe it was already asked somewhere in the previous 25 pages, but would it be possible if the number of segments is variable and the input sheet adjusted accordingly? and have a bit more than 4 segments?
Another, probably more difficult to answer question, could stuffing be added to each segment? this may not be important to the typical horn, but for the TL fraction out here this is very important.
Hi Henkjan,
Your first question has been asked previously - see Post #478 for my answer.
As I recall, your second question has also been asked before - the answer is effectively the same as that given for question one :-).
Kind regards,
David
www.hornresp.net
Old 20th June 2009, 06:59 AM   #627
Only having a brief manual and discovering features as you go has it's charmes
Hi Henkjan,
All features are documented in the Hornresp Help file. It should not be necessary to discover anything :-).
Kind regards,
David
www.hornresp.net
Old 20th June 2009, 07:05 AM   #628
Default Re: Re: HORNRESP VERSION 22.20
Hi Jean-Michel,
It looks good. The results are as expected :-).
Kind regards,
David
www.hornresp.net
Old 20th June 2009, 07:10 AM   #629
Only if it doesn't require too much work - I'll have a look and see what would be involved.
Hi Cordraconis,
Further to my post above, just confirming that volume details will be added to the Horn Segment Wizard in the next release.
Kind regards,
David
www.hornresp.net
Old 20th June 2009, 07:19 AM   #630
Default Re: Re: Re: Re: HORNRESP VERSION 22.10
I'm not sure how much work would be involved - I will investigate further.
Hi Jean-Michel,
Further to the above, the attached screenprint shows the constant directivity power response of a TD2001 driver and Le Cléac’h horn (320Hz, T = 0,8) with a constant diaphragm acceleration of 1000 cm/sec2. The equivalent on-axis pressure response is shown in grey.
Based on these results, I am not sure that there would be much to be gained by including a constant acceleration option in the production version of Hornresp. Do you agree?
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
