#561 |
Is there a guide somewhere to modelling OS waveguides?
Ta
#562 | ||||||
Hi David_Web,
Kind regards, David
www.hornresp.net |
#563 | |
Me too :-). The interesting thing is, in this particular case there is an inconsistency in AkAbak itself. A duct closed at one end is treated differently to a waveguide closed at one end. Using node 0 with a waveguide generates an error message. Kind regards, David
www.hornresp.net |
#564 | |
Not that I am aware of. Press the 'O' key when the L12 input text box has the focus to select "Obl" for an oblate spheroidal waveguide. The Horn Segment Wizard can be quite useful when working with OS waveguides. Kind regards, David
www.hornresp.net |
#565 |
For measuring the horn length, which is the proper/better method in the drawings A & B of the same box.
The Box B is in the next post |
#566 |
Here is Box B
#567 |
"As a general principle, I prefer to use modal forms rather than allowing multiple windows to be accessed"
Sometimes I find that hornresp covers the data I need when entering driver data meaning I have to close the dialog to move hornresp out of the way. It's fine the way it is but I thought it might be easier to work with. "Sorry - that would require too much work :-)." I knew it! "Jean-Michel came to the rescue though :-)." "I am sure that Jean-Michel will be pleased to see that his method is working well." Thanks! It works great. Now I just have to keep modeling to get the best IR I can. Ill have to measure the IR of the TH I built and see if it looks similar. When not using damping in a box I get excessive odd ringing of sort, not a problem per see but a little annoying when you want to model a BR and then get a proper IR of it. Will damping and port be separate in the future? btw I still think damping creates odd phase and GD shifts. Try a way to small box for a driver, the GD will see a smooth hump at resonance as it should, now add some damping and you get sharp corners and a less wide hump. Not affected by stuffing density. |
#568 | |
#569 | |
Thanks David ![]() Is there anything particular to enter for driver params? (for compression drivers)
#570 | |
I use to feel like the small child in The Emperor's New Clothes tale
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
