#541 | |
It is interesting to note that your Hornresp problems only seem to have started after the filter was added to the Find tool, and the record limit was increased to 9999. As far as running out of virtual memory is concerned, while I am no expert, from your description it sounds like it could be a machine configuration problem. Does the ‘Subscript out of range’ error occur only when the Find tool is used, or can it be generated at other times as well? Thanks. Kind regards, David
www.hornresp.net |
#542 |
Greets!
True. No, I occasionally get it same as jogi59 and as I alluded to previously it appears to be all about SAVE, just that I normally am using FIND to trigger a SAVE, but I can sometimes trigger it by clicking ADD and hit BACK to save it. WRT running out of virtual memory, I haven't opened HR since a reboot several days ago, but have had a NAV update, so to my computer illiterate observation, HR is starting to look like the probable culprit. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#543 | |
Thanks for this. I will include some further changes in the next update in an attempt to address both the ‘Subscript out of range’ error and the virtual memory problem. I will let everyone know when Version 22.00 is released. Kind regards, David
www.hornresp.net |
#544 | |
When you open the Windows Task Manager and select the 'Processes' tab, what is your Hornresp.exe 'Mem Usage' figure? In my case, the value never exceeds 5,000K, which is really nothing in the grand scheme of things (only 5MB), and is about what I would have expected to see. Thanks. Kind regards, David
www.hornresp.net |
#545 |
Does anyone know why Hornresp shows a falling response with a front loaded horn, while Akabak does not?
I took a FLH that I made in Hornresp, exported it to Akabak, and the drooping response was flattened in Akabak. I have a feeling that Hornresp is correct, as a conical horn should form an acoustic low pass. But Akabak is usually quite accurate... I checked LE to be sure it was correct, it's the only thing that I could think of... |
#546 |
David,
I exported a tapped horn design to Akabak. I notice that the first duct segment has nodes 7 and 8. Node 7 has nothing attached to it. Intuitively, this should act as an open-ended duct, but Akabak appears to treat it as a closed end duct. (The horn response is unchanged if I change the node to 0, explicitly closing it.) So it works OK, but more by default than by design. More of a nit than a bug... |
#547 | |
Are you comparing the Hornresp constant directivity SPL response to the AkAbak acoustic power response or to the AkAbak acoustic pressure response? Hornresp (resonances not masked) and AkAbak power results should be identical. AkAbak includes a simple directivity model in the acoustic pressure response calculations which extends the high frequency response. You would need to use the Hornresp directivity tool in that case to get a meaningful comparison (bearing in mind that the Hornresp directivity model is more sophisticated than the one used in AkAbak). Hope this helps. Kind regards, David
www.hornresp.net |
#548 | |
What version of Hornresp are you using? A tapped horn design exported from Hornresp (either 3 or 4 segments) should not specify node 7 anywhere. Segment 1 is specified by nodes 8 and 9 Segment 2 is specified by nodes 9 and 10 Segment 3 is specified by nodes 10 and 11 Segment 4 is specified by nodes 11 and 12 To allow me to investigate further, could you please post a copy of the Hornresp-generated tapped horn AkAbak script showing the use of node 7. Thanks. Kind regards, David
www.hornresp.net |
#549 | |
On further testing I find that under worst-case conditions with the Help file open and running the Wavefront Simulator etc, I can get the memory usage up to about 7 MB. Still not much though... Kind regards, David
www.hornresp.net |
#550 |
Greets!
OK, I opened HR late last night and it started out at 4192K, did a FIND, ADD, PREVIOUS, SAVE and it's up to 5712k. Another set and it only increases to 5724k. Minimizing it drops it to 1108k. This morning I was greeted with the virtual memory too low error message. Coincidence? Dunno, I'll have to reboot and try again to see how long it takes without opening HR. GM
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
