| Thread Tools | Search this Thread |
#41 | |
Hi Sabbelbacke, No problem :-). If you find any more bugs, please let me know. Kind regards, David |
#42 |
Hi David,
First, thanks for a great tool! Question... With a conical or OS, I am seeing directivity dramatically narrow just above LF cutoff. Is this because there is no baffle or mouth treatment? If not, what does cause it? Thanks, Paul |
#43 |
That seems to be characteristical for conical horns. I remember Tom Danley posting about this, but not where, maybe the audio asylum. In the unity and synergy horns this is countered with a short horn segment at the end of the horn which has a slightly wider angle than most of the horn. But it seems that hornresp cant simulate the radiation pattern for multi segment horns, so i cannot check if this is true.
#44 | |
It gets a bit complicated, but essentially the effect is due to the shape and size of the wavefronts in a conical horn relative to wavelength. Note that the directivity narrowing actually occurs in practice - it is not just in the simulation results that you will see it. Kind regards, David |
#45 |
Hi Everyone,
Hornresp Version 19.00 has just been released. Changes are: 1. Offset driver horns can be modelled. See Note 7 on page 15 of the Help file for details. 2. The tapped horn option is selected differently. See Note 8 on page 15 of the Help file for details. 3. The Multiple Drivers tool is now the Driver Arrangement tool. The number and position of drivers can be specified. 4. The profile information for the left and right side walls of a rectangular cross-section horn is now also exported, where the data can be directly calculated. See Note 14 on page 17 of the Help file for details. 5. A bug in the Tapped Horn Wizard which “froze” the program under some circumstances, has been fixed. Kind regards, David |
#46 |
Thank you David. Us hornies owe you a large debt of gratitude.
#47 |
Yay for the offset driver option! Building my unity/synergy horn would have been alot easier this way. But now i can use it in my first revision
#48 |
Once again: THANK YOU!!!!
#49 | |
Would you say a bit more about this? I'd like to understand the root cause a little better. Thanks, Paul |
#50 |
I only started using this program last week, and it's excellent.
I just want to say thanks and keep up the good work. |
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
| Page generated in 0.14753 seconds (71.38% PHP - 28.62% MySQL) with 11 queries |
