Hornresp
Hornresp
Old 26th April 2009, 05:23 AM   #471
David McBean is offline David McBean  Australia
Originally posted by David_Web
Will you add the ability to compare previous measurement with F4 as well?
Also export the IR to wave or other format that can be turned into it?
Hi David_Web,
At this stage I have no plans to add a comparison feature to the Impulse Response tool or to export the results.
Kind regards,
David
www.hornresp.net
Old 26th April 2009, 05:36 AM   #472
Originally posted by Sabbelbacke
I've been very busy in the last few weeks so I didnīt have the time to take closer looks at the new versions.
Hi Sabbelbacke,
Not a problem. If you do find any bugs in the future, please let me know.
Kind regards,
David
www.hornresp.net
Old 29th April 2009, 10:17 PM   #473
iand is offline iand  United Kingdom
Hi David
Any chance (i.e. can it be done simply!) of making Hornresp able to cope with multiple drivers at different positions in a tapped horn, to try and tame some of the resonant peaks by averaging them out?
Cheers
Ian
Old 30th April 2009, 04:03 AM   #474
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Is there any way to get an impulse response with a tapped horn? BTW, made our first tapped horn last night. UNBELIEVABLE!!!
PASSIONN
Old 30th April 2009, 04:25 AM   #475
Mach5 is offline Mach5  United States
********Feature request********
I was trying model a driver mounted to the sides of a tractrix horn(danley style)
My suggestions
1. allow horn segments before tractrix, OS, l'cleach segment
2. Change the way segments are handled to allow for more segments(say 200)
and I can simulate them in conical segments
Of either option needs to still work in offset driver mode
Old 30th April 2009, 06:14 AM   #476
Hi Ian,
Sorry, no chance - it would require just too much work :-). You could always use AkAbak, though.
Kind regards,
David
www.hornresp.net
Old 30th April 2009, 06:25 AM   #477
Hi brsanko,
I hope to eventually enhance the Impulse Response tool so that it can be applied to any horn system. It may take me a few weeks though - I am a bit busy at the moment :-).
Kind regards,
David
www.hornresp.net
Old 30th April 2009, 06:33 AM   #478
Originally posted by Mach5
My suggestions
Hi Mach5,
Unfortunately the features you suggest would require a complete re-build of Hornresp. Sorry, it is just not going to happen :-).
Kind regards,
David
www.hornresp.net
Old 30th April 2009, 03:07 PM   #479
GM is offline GM  United States
GM's Avatar
Greets!
Short of reusing older sims, is there a way to increase the 999 limit or choose which .dat file to load?
TIA,
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st May 2009, 08:34 AM   #480
Hi GM,
It is not possible for Hornresp users to increase the 999 limit or to choose a different data file to load. I was wondering when you would reach the limit - I could see from your recent input parameter screenprints that you were starting to get close. You must be the only person in the world to have 999 records in Hornresp :-).
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
