Hornresp
Hornresp
Old 12th February 2014, 01:35 PM   #4201
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Originally Posted by zak1976 View Post
Hi David,
since i have found your great pice of software, nearly all other loudspeaker calculators have gone to the recycle ...
Nowadays diplays with Full HD resolution are standard, I am missing the option to scale the graphs in Hornresp, the Hornresp window is very small compared to the diplay resolution. It would also be nice to specify a custom frequency range the it is easier to focus on the range which is important for subwoofer design.
Is there a chance to get these features in a further release of Hornresp?
+1!!!
Old 12th February 2014, 03:21 PM   #4202
tb46 is offline tb46  United States
Default Post #4196
Hi David,
Thanks for the lastest update. :-)
Oliver
Old 13th February 2014, 06:36 AM   #4203
David McBean is offline David McBean  Australia
Hi zak1976,
At this late stage in the evolution of Hornresp it would just be too much work to go back and modify everything to make the windows sizable. The formatting of controls has been carefully optimised to the current fixed window size - I would rather not change this.
Are you using the 125% magnification option with your display? I find that it makes the Hornresp window a nice convenient size on my 1600 x 900 pixel LCD monitor.
This feature has been requested before - see link below. The answer remains the same :-).
Hornresp
AkAbak of course, supports user-sizable windows and custom frequency ranges...
Kind regards,
David
www.hornresp.net
Old 13th February 2014, 08:45 AM   #4204
zak1976 is offline zak1976
What a pity, but still a great programm.
Old 16th February 2014, 05:12 AM   #4205
Default Hornresp Update 3400-140216
Hi Everyone,
CHANGE 1
Slight modifications have been made to several of the Hornresp Help file descriptions.
CHANGE 2
A minor bug in the Data File Editor tool has been fixed.
Kind regards,
David
www.hornresp.net
Old 2nd March 2014, 05:06 AM   #4206
Default Hornresp Update 3410-140302
Hi Everyone,
CHANGE 1
The combined response 'path length difference' parameter value is now saved as part of the Hornresp.dat file permanent data record.
CHANGE 2
The Sample tool slider range is now 1 - 20000Hz rather than 0 - 19999Hz.
The Pattern tool slider range is now 1 - 20000Hz rather than 0 - 20000Hz.
CHANGE 3
Minor amendments have been made to the Loudspeaker and Filter wizard descriptions in the Help file.
Kind regards,
David
www.hornresp.net
Old 2nd March 2014, 03:12 PM   #4207
nc535 is offline nc535
Hi David:
The filter wizard is great as is but would be even better if there were
even just 1 PEQ term available in the active mode of the filter wizard; one each for LP and HP when doing bandpass.
Thanks,
Jack
Old 2nd March 2014, 10:02 PM   #4208
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Just downloaded it and will be playing....
Mark
www.kravchenko-audio.com
Old 3rd March 2014, 01:05 AM   #4209
Mark Kravchenko
Hornresp
Been playing with the new stuff, and I likes it. I likes it a lot.
Mark
Old 3rd March 2014, 05:18 AM   #4210
Originally Posted by nc535 View Post
The filter wizard is great as is but would be even better if there were even just 1 PEQ term available in the active mode of the filter wizard; one each for LP and HP when doing bandpass.
Hi Jack,
If by PEQ you mean full parametric equalisation, then it's not going to happen :-).
Allowing second and fourth order active filters to be specified using cutoff frequency and Q factor is about as far as I am prepared to go.
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
