Hornresp
Hornresp
Old 8th April 2008, 04:31 AM   #31
David McBean is offline David McBean  Australia
Originally posted by Sabbelbacke
When using the max-SPL feature, a given limitation due to excursion is labeled as "power limited". Itīs late already, am I thinking right, shouldnīt it be "xmax limited"?
Hi Sabbelbacke,
Your thinking is exactly right :-).
Thanks for bringing the error to my attention - it has now been fixed.
Product Number 1830-080408 refers.
Kind regards,
David
Old 8th April 2008, 04:46 AM   #32
Originally posted by Ivo
What more can we expect? I would be interested in a tapped horn alignment wizard (enter length and driver and the wizard sorts out optimal driver position, that sort of thing).
Hi Ivo,
I suspect that it could be very difficult to develop an automated tapped horn alignment wizard along the lines that you have suggested. The latest "scroll bar" version is probably the best that I can come up with :-).
I am currently working on developing an offset driver model. Because of the magnitude of the changes required to Hornresp, it will be released as Version 19.00.
Kind regards,
David
Old 8th April 2008, 08:32 AM   #33
Sabbelbacke is offline Sabbelbacke  Germany
Thanx again David!!! I just tried it, old data works again and "excursion limited" is back, too
Just noticed one minor thing, which might be "on purpose" after all:
If I use the "tapped horn slider wizard", leave the dialog via "save" button and donīt calculate again, there is no safety "save data" pop up like usual. Leaving the current design via "next/previous" or quitting hornresp results in loss of the new values from the wizard.
Best regards
Old 8th April 2008, 07:47 PM   #34
tb46 is offline tb46  United States
Default Error fixed.
Hi David,
Thanks for the quick follow up. I second Sabbelbacke's remark on the "save data" issue. Otherwise everything seems to work just fine.
Wish I could say the same about my old simulations, as old fumble fingers managed to loose two month worth of playing. Note to self: moving a file is not the same as copying a file.
Oh well, thanks again, Regards
Oliver
Old 8th April 2008, 10:44 PM   #35
Ivo is offline Ivo  Netherlands
It's great already, I was just pushing it a little, since you are open to such things.
Did I spark that after all?
We want to be happy, bold and free
Old 11th April 2008, 05:24 AM   #36
Hi Sabbelbacke,
It is definitely not on purpose :-).
Thanks again for the great feedback, the error has now been fixed - Product Number 1830-080411 refers.
This will teach me not to work on the program when I should really be sleeping :-).
Kind regards,
David
Old 11th April 2008, 05:27 AM   #37
Hi Ivo,
You certainly did :-).
Kind regards,
David
Old 11th April 2008, 05:34 AM   #38
Default Re: Error fixed.
Thanks Oliver.
Your comment has reminded me of something - my next posting refers :-).
Kind regards,
David
Old 11th April 2008, 05:37 AM   #39
Default USER NOTE - CORRUPTED HORNRESP.DAT FILES
Hi Everyone,
A few users have reported problems with corrupted Hornresp.dat data files. When investigated, the corruption is invariably found to be due to switching back to an earlier version of Hornresp after having opened the data file with a more recent version of the program.
Please note that the program automatically updates an existing data file as necessary with each new release. Once a data file has been opened using a particular version of Hornresp, under no circumstances should that file then again be used with an earlier version of the program. The safest course of action is to delete any earlier version of the program that you may be using, each time you download a new release.
An earlier version of the program has no way of knowing how to interpret a data file that has been modified by a later release of Hornresp.
Kind regards,
David
Old 11th April 2008, 09:35 AM   #40
Hy David.
Thanx for the helpfull reminder and the quick fixup
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
