Hornresp
Hornresp
Old 28th October 2013, 07:48 AM   #3751
David McBean is offline David McBean  Australia
Originally Posted by Beau View Post
When simming a tapped horn for dual drivers, is using the center between the drivers sufficient for locating them or is there another method?
Hi Beau,
With Hornresp, use the centre point between the two drivers. For the purposes of the simulation a single "composite" driver is assumed, as shown in the schematic diagram. AkAbak could be used to specify more precise locations for the two separate drivers if so desired. I'm not sure how much of a difference this would make to the overall results at bass frequencies, though.
Kind regards,
David
www.hornresp.net
Old 29th October 2013, 11:12 AM   #3752
Default Hornresp Update 3240-131029
Hi Everyone,
The Driver Front Volume tool has been enhanced and two operating anomalies have been corrected.
DRIVER FRONT VOLUME TOOL
Previously the red outline showing the driver volume could sometimes have a small gap at the point where the cone joined the dust cap. This red line is now continuous at all times.
The driver volume cross-section is now highlighted in yellow to remove any ambiguity surrounding the volume being calculated - see Attachment 1.
ANOMALY 1
Selecting and then cancelling either the File > New, File > Open or File > Editor menu command when a record was Edit mode and the Tools > Loudspeaker Wizard menu command was enabled, would leave the Tools > Loudspeaker Wizard menu command enabled and the Edit button disabled, even though the record was no longer in Edit mode - see Attachment 2.
Being able to select the Loudspeaker Wizard with a record not in edit mode resulted in a fatal error being generated when the Wizard was exited - see Attachment 3.
ANOMALY 2
Holding down the F5 function key or multi-clicking the main Calculate button while results were being calculated would allow the Window menu commands to be displayed with two viewing flags simultaneously checked - see Attachment 4.
Kind regards,
David
www.hornresp.net
Old 29th October 2013, 11:42 AM   #3753
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Kool!
Every day, and in every way, getting better and better.
A slight play on the words uttered by inspector Dreyfus in one of the pink panther movies.
But it almost fits.
Need a slightly twitching left eye to!
Keep it up David. You keep pushing the envelop, and expanding your programming capabilities. Done quite a few things that out of your comfort zone. And I am very grateful you are willing to keep progressing.
Makes my life so much easier!
Mark
www.kravchenko-audio.com
Old 31st October 2013, 05:18 AM   #3754
Default Hornresp Update 3240-131031
Hi Everyone,
The Driver Arrangement and Multiple Speakers tools now have the drivers and speakers coloured in yellow to make them easier to see.
'Before' and 'after' screenprints are attached.
Kind regards,
David
www.hornresp.net
Old 31st October 2013, 05:21 AM   #3755
Originally Posted by mwmkravchenko View Post
Keep it up David.
Hi Mark,
As you can see from my post above, I couldn’t resist making yet another small "tweak" :-).
Kind regards,
David
www.hornresp.net
Old 31st October 2013, 04:48 PM   #3756
Mark Kravchenko
Hornresp
Looks good to me.
Mark
Old 3rd November 2013, 04:43 AM   #3757
Zero D is offline Zero D  United Kingdom
Default Webroot Warning
@ David McBean
Thought i'd let you know that WSA is still showing a warning ?
Old 3rd November 2013, 05:48 AM   #3758
Hi Zero D,
Thanks for the feedback.
Sabbelbacke is the expert in these matters, but it seems that direct access to "www.hardware-test.de" has been restricted using a robots.txt file.
https://support.google.com/webmaster...r/156449?hl=en
To download Hornresp, use either "www.hardware-test.de/mcbean" or "www.hornresp.net".
Kind regards,
David
www.hornresp.net
Old 3rd November 2013, 06:08 AM   #3759
After a bit of detective work, I think the attached file may be the one being used.
Kind regards,
David
File Type: txt robots.txt (111 Bytes, 9 views)
www.hornresp.net
Old 3rd November 2013, 08:48 AM   #3760
Sabbelbacke is offline Sabbelbacke  Germany
@ David McBean
This is a false warning - there simply is no content whatsoever on the entry page of STRATO.
What one sees is the entry page for blank sites, provided by the hosting Company.
For downloading hornresp, use the links provided by David in the post above.
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
