Hornresp - Page 361 - diyAudio
Old 8th July 2013, 01:55 PM   #3601
tb46 is offline tb46  United States
Hi David,
Rane has some nice papers on filters, one is on the Bessel filter: A Bessel Filter Crossover, and Its Relation to Others .
Oliver
Old 8th July 2013, 03:00 PM   #3602
Originally Posted by Jeff B View Post
..........The first order filter is only Butterworth. You can't vary the Q on the first order filter.
I do not know the coefficients for higher order Bessel, or even if they exist.
the coef for all the traditional filter types exist.
As far as I'm concerned the standard single pole RC or CR filter is a Butterworth with a Q=Sqrt(2).
Some have said I am wrong, but I just left them believing I'm the fool.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th July 2013, 07:32 AM   #3603
Hi Jean-Michel, Jeff, Oliver and Andrew,
Thanks for your comments - they help me to better understand how the Hornresp Filter Wizard could perhaps be enhanced a little.
Kind regards,
David
www.hornresp.net
Old 9th July 2013, 02:13 PM   #3604
Hi David,
I hope I didn't open too much of a can of worms for you, but I now understand a little more about using Hornresp and Jeff's software.
One question that comes up when using the Filter Wizard is: is it possible to add a button to the Filter Wizard that transports the filtered SPL curve into the main window, so that the filtered SPL curve can be used as the basis for impulse and group delay graphs? I'll attach a typical Filter Wizard window as an example.
Either way, thank you so much for your continued effort, and for making Hornresp such a wonderful tool.
Oliver
Old 10th July 2013, 08:04 AM   #3605
Phi = -ATAN2 (X,Y)
Hi Jeff,
Just to clarify - am I correct in assuming that you actually meant to say Phi = ATAN2 (-X,Y)?
Kind regards,
David
www.hornresp.net
Old 10th July 2013, 08:30 AM   #3606
Hi Oliver,
Unfortunately from an operational perspective that would complicate things greatly for me. As far as the Filter Wizard itself is concerned though, I hope in the next release to include three additional active filter charts showing filter phase shift, filter group delay and overall filter plus speaker group delay - all results calculated in real time.
Kind regards,
David
www.hornresp.net
Old 10th July 2013, 10:13 AM   #3607
Originally Posted by David McBean View Post
Hi Jeff,
Kind regards,
David
No, the way I wrote it is the way it is used in Excel. However, there are several things in Excel that are quirky, like needing to convert to Radians. I'm not sure if the way you wrote it would yield the correct result, but it would be easy enough to test and see.
Old 11th July 2013, 07:27 AM   #3608
Hi Jeff,
For a 4th-order Butterworth low-pass filter with a cutoff frequency of 100 Hz:
Phi = ATAN2 (-X,Y) gives the result shown in Attachment 1.
Phi = -ATAN2 (X,Y) gives the result shown in Attachment 2.
Phi = ATAN2 (-X,Y) removes the phase wrapping at 100 Hz, but shows the phase starting at 180 deg rather than at 0 deg. I have noticed that this "unwrapped" presentation often seems to be the format of choice, which is why I sought the clarification. It makes no difference to the group delay results of course, which way the phase is calculated.
Kind regards,
David
www.hornresp.net
Old 11th July 2013, 09:50 AM   #3609
Hi Jeff,
Kind regards,
David
I am not sure what you mean by format of choice, but attachment 2 (-ATAN2 (X,Y) is the correct phase. For a 4th order slope the phase should be at 180 degrees at Fc and wrap at that point. Attachment 1 is not correct.
Old 11th July 2013, 01:59 PM   #3610
Hi David,
Post #3606: "...I hope in the next release to include three additional active filter charts showing filter phase shift, filter group delay and overall filter plus speaker group delay - all results calculated in real time."
Looking very much forward to that. Thanks,
Oliver
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright 1999-2017 diyAudio
