Hornresp
Hornresp
Old 19th June 2013, 01:34 PM   #3541
tb46 is offline tb46  United States
Hi simonpink,
For a standard folded construction, with equal duct height (width) throughout the enclosure, you might set the height to the internal enclosure height (width), e.g.: 40cm, and use smaller increments, e.g.: 2.54 (if you want to work in inches). I like to just calculate the values for duct height @ e.g.: S1 in a spreadsheet, and draw the results in a CAD program as a profile. Then I get my values from that drawing.
Oliver
Old 19th June 2013, 04:04 PM   #3542
simonpink is offline simonpink
So I put 40 in the height column like this?
When I open the exported excel file from that I've got height measurements of 20cm? And the product of the width and height isn't equal to the area at each increment along the S1 section, or any of them?
File Type: png Screen shot 2013-06-19 at 11.54.38 PM.png (19.1 KB, 132 views)
File Type: png Screen shot 2013-06-19 at 11.57.35 PM.png (21.7 KB, 130 views)
Old 19th June 2013, 04:54 PM   #3543
kees52 is offline kees52  Netherlands
@simonpink you need to set height to for example 33 cm for a 12 inch woofer, then export.
for a 5 segment tapped horn you need Th1 I think but then you have bad respons as I see. I did use TH1
I do see you use a dayton UM-15, this woofer is not a good candidate, high qts, high vas, low FS beauty
for closed box. Transition from S1 to S2 it is difficult to mount a speaker.
regards
Old 19th June 2013, 05:11 PM   #3544
Hi simonpink,
In your example Post #3542: note that it says Height/2 and Width/2 in the column headings. So you get e.g.: 20 x 2 and 4.375 x 2, and that gives you the area in column B of 350.
Oliver
Old 20th June 2013, 03:12 AM   #3545
NEO Dan is online now NEO Dan  United States
NEO Dan's Avatar
Hi Simon,
You might want to start by setting all values in the width column to the desired width of the TH. It's laods easier to build one that way IMO...
Dan
Old 20th June 2013, 08:57 AM   #3546
I've got it! I was able to bring it into 3D and the calculated volume matched the hornresp sim. Thanks heaps for your help, guys!
Old 20th June 2013, 04:51 PM   #3547
Hi David
Still I get strange outcomes from hornresp when export conical.
Because of this I don,t trust this because if wrong I possibledo hours
or work for nothing when folding, when I do export exponential then it works
also par and uni works.
everything is in zip also design import.
regards
kees
Old 20th June 2013, 05:37 PM   #3548
I have here a sample of the box, look at the flare and tekst.
it is exp, the con one has a lot of other values some 1 cm more flare somewhere around 150 cm from S2 speaker startpoint, therefore I did not trust the conical one, exp seems to fit wel but has bumps in flare on some places, maybe this is because of sketchup...
regards
kees
Old 22nd June 2013, 06:23 AM   #3549
David McBean is offline David McBean  Australia
Default Hornresp Update 3220-130622
Hi Everyone,
Changes:
1. The problem reported by Kees in Post #3547 has been fixed.
2. A fatal error occurred when trying to print a hard copy of the group delay chart. This problem has now also been fixed - the bug was introduced when the Filter Wizard tool was added.
Kind regards,
David
www.hornresp.net
Old 22nd June 2013, 06:26 AM   #3550
Hi Kees,
Thanks for reporting this issue. The problem has been fixed in the latest release.
Width / 2 values now remain constant along the length of the horn when the entered S1 and S2 width values are the same. Previously under some circumstances the Width / 2 values could vary.
Note that Height / 2 values can sometimes vary even when the entered S1 and S2 height values are the same. This is because the Con, Exp and Uni flare settings apply to the width, not the height.
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
