Hornresp
Hornresp
Old 7th June 2013, 12:43 PM   #3521
kees52 is offline kees52  Netherlands
Yes Helping people, or nature makes you healthy or anyone else who do this, and it makes more satisfaction then anything else and so relaxed and such.
I helping my mother now who is 81 and there friend is hospitalized and was on the edge of death but go better now, he is also aged, 74 years so les capable to recover but it go succesfull this time.
Thanks again.
Old 12th June 2013, 04:28 PM   #3522
Hi David
I have done a exp tapped horn with more wood parts for the flare.
I do see that there is a bump on the beginning of the horn, see pictures, it looks
that it is sketchup who do this or the S2 start is faulty..
regards
kees
Old 13th June 2013, 08:06 AM   #3523
David McBean is offline David McBean  Australia
Originally Posted by kees52 View Post
Hi David
regards
kees
Hi Kees,
I would need more information to be able to comment on your results:
* Screenprint of 'Input Parameters' window.
* Screenprint of 'Export Horn Data' form.
Kind regards,
David
www.hornresp.net
Old 13th June 2013, 08:45 AM   #3524
Originally Posted by David McBean View Post
Hi Kees,
Kind regards,
David
Hi David
The problem was sketchup, sometimes it jumps 0,1 cm or even more, in my case
redrawn it make it oke again.
I go learn autocad, sketchup is nice but has to much things I do not like.
Good for fast drawns but for exp flare autocad is better.
regards
kees
Old 13th June 2013, 02:05 PM   #3525
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
That's the EXACT reason why I don't use Sketchup.
Old 13th June 2013, 02:06 PM   #3526
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Can't say I like Sketchup either.
Mark
www.kravchenko-audio.com
Old 13th June 2013, 05:16 PM   #3527
I have the problem with sketchup that it jumps sometime, special when closed and the next day opened I see it is jumped 0,1 mm.
also it does what it want itselfs, not always what i want.
I have autocad, but it is not so easy to use, a simpel precise drawn program I have not yet see what I like.
But I have drawn the exponential tapped horn, but to long, so I have to calculate noi now the bends..
regards
Old 14th June 2013, 08:34 AM   #3528
Excellent - no work for me :-).
www.hornresp.net
Old 14th June 2013, 09:10 AM   #3529
Yeahh you are lucky.
Old 14th June 2013, 06:11 PM   #3530
Djim is offline Djim  Netherlands
Hi David,
Is it possible to add 2 Symmetric-TH models? (STH of which the path is cut in two symmetric halves). It doesn't need extra reference points, only a change of the driver position from S2 to S1.
The reason I ask, if we now want to model a STH we have to give up one S-reference point (see green arrow) which limits the flexibility we usually have.
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
