Hornresp - Page 349 - diyAudio
Old 17th May 2013, 07:06 AM   #3481
Originally Posted by kees52 View Post
Do you have removed the filter wizzard? I don,t see it anymore.
Hi Kees,
The Filter Wizard is selected from the SPL response chart window. The tool is disabled when Eg is set to zero, or when maximum SPL has been calculated.
It's all in the Hornresp Help file :-).
Kind regards,
David
www.hornresp.net
Old 17th May 2013, 07:26 AM   #3482
Originally Posted by more10 View Post
Push "t" while cursor is in the L12 field. L23 must be 0,0.
Hi more10,
Just to clarify - L23 does not have to be zero before the T key is pressed. Hornresp will automatically set a non-zero value to zero.
Kind regards,
David
www.hornresp.net
Old 17th May 2013, 07:42 AM   #3483
I have did some tests, with a conical flare it is oke, with a uni flare it is not see zip example.
Hi Kees,
The values listed in your zipped-up Con-flare.txt and conical.txt example files seem fine to me. What is it about these results that concerns you?
Kind regards,
David
www.hornresp.net
Old 17th May 2013, 08:43 AM   #3484
more10 is offline more10  Sweden
Hi David
In the thread building a pair of JBL 4520 with different components. some help! retro soulman uses a JBL E130 and a K140 in a JBL 4520 box. At first I shook my head, but he might have a point. Combining the midrange of the E130 with the low end of the K140.
I know your response will be that it will never happen, but we have heard that before :-). I would like to add to the wish list the ability to define two different drivers to be used at the same time.
It would be fun to simulate this setup.
Old 17th May 2013, 10:02 AM   #3485
kees52 is offline kees52  Netherlands
here it is.
I did see that only the uni-flare export is faulty, the conic one is oke.
ca send someone me a older hornresp of tree updates back for test.
Old 17th May 2013, 10:12 AM   #3486
Originally Posted by David McBean View Post
Hi Kees,
Kind regards,
David
Hy David.
Post some tekst from it in here.
I get very strange outcomes see here. the first part of the export horn data is faulty, the rest is fine, strange
that you get good output, send me a older version of hornresp..
S1=faulty
Length (cm) Area (sq cm) Radius (cm) Angle (deg) Side Len (cm) Height/2 (cm) Top Len (cm) Width/2 (cm) Width Flare
0.000000 135.000000 6.555291 1.754989 0.000000 (Here-fault 0.013357) 0.000000 (Here-fault 2526.810303) Uni
0.500000 135.631000 6.570593 1.750904 0.500091 0.013419 0.500000 2526.800738 Uni
1.000000 136.262000 6.585859 1.746848 1.000183 0.013482 1.000000 2526.791172 Uni
but S2 is oke
0.000000 185.480000 7.683757 1.471426 0.000000 (Here-oke 16.500000) 0.000000 (Here-oke 2.810303) Uni
0.500000 186.100061 7.696589 1.468974 0.500088 16.500000 0.500000 2.819698 Uni
1.000000 186.720123 7.709401 1.466533 1.000177 16.500000 1.000000 2.829093 Uni
1.500000 187.340184 7.722191 1.464106 1.500265 16.500000 1.500000 2.838488 Uni
When I do export conical horn output everything is fine.
I did again uni output but now it again a weird output, the height is not continu 33 cm, in uni flare.
I go search a older version of hornresp to test, then I do now if it is the pc.
I have to say I do use increments of 0.5 cm and 1 cm for the flare so I can make a precise fold
maybe then it go wrong, so David do use 0.5, 1, 1 cm increments when test it there.
regards
kees
Old 17th May 2013, 11:29 AM   #3487
Well I have found it and so i share it, it is a very strange fenomen, it happes only when I use keyboard when fill in hornresp horndata height (33cm) with enter.
When I use the mouse cursor to fill in the horndata and not enter from the keyboard then the output is oke here, I really don,t now why this happens, is it a bug or is it in my pc himslefs (after the lightning hit nabures who I did feld trough the mouse (static).
The pc does more now well, like hanging refreshing screen in sketchup, and crash sketchup.. But i think the pc can not be half broken, it works or not.
yesterday I did sketchup and have no problem with hanging screen, that happens in sketchup when I have to many guides.
If someone have a older version of Hornresp I can try if these also do strange behavior with keyboard.
regards
kees
Old 18th May 2013, 06:32 AM   #3488
Hi more10,
Sorry, but I cannot see it ever happening in Hornresp :-).
One-off unconventional designs such as these are better suited to simulation in AkAbak.
I suspect that the actual performance of such a loudspeaker would be less than satisfactory anyway...
Kind regards,
David
www.hornresp.net
Old 18th May 2013, 07:13 AM   #3489
Hi Kees,
Many thanks for this additional information. While I cannot replicate your exact values, I also get strange results for your example design when the Uni width flare option is selected - and it doesn't matter how I enter the 33cm height value for S1.
There is obviously a problem somewhere - I will investigate further and let you know what I find.
Thanks for persisting with your investigations to establish the sequence of events that causes the error - it helps me greatly when looking for the bug.
Kind regards,
David
www.hornresp.net
Old 18th May 2013, 11:02 AM   #3490
Hi David
If I do input with mouse and keyboard without using enter on keyboard then I get the right outcome, I have tryed this 25 times, anly with input through enter give this strange outcome.
Possible the proper outcome is for me looking good it is afcourse possible that the flare calculation is not precise, this is difficult to so see, but I have drawn and folding the box and the flare is
not exact, but maybe there is always some differency because of that.
Have you tryed a older version? maybe there it is oke and is something after later bug looking.
in picture example of box so far I been with folding, it is a day work already.
Thanks for your response, and you are welcome.
regards
kees
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright 1999-2017 diyAudio
