Hornresp
Hornresp
Old 14th May 2013, 08:38 AM   #3471
David McBean is offline David McBean  Australia
Originally Posted by kees52 View Post
I have problems I think with new version. I do see it do not fill in proper width it need to be 33 : 2 =16.50 but it is 16.49 for S2 but S1 give 0.013485??.
very strange outcomes with horn data,
when I do S1 135 2cm it is a strange outcome, do i miss something or is there a bug, maybe S1 135 2cm is to small, or there is a bug, from S2 it is oke.
Never seen this.
Hi Kees,
For your given example, and using the default square cross-section height and width dimensions together with the Uni width flare option as shown in the first attachment, the exported data should be as listed in the second attachment. I have no idea why your results are not the same as those in attachment 2.
Kind regards,
David
www.hornresp.net
Old 14th May 2013, 10:37 AM   #3472
kees52 is offline kees52  Netherlands
[QUOTE=Zero D;3489920]
Yeah me too Nothing bad happens when i visit -http://www.joynic.com but it's strange how you got there ?
Are you SURE you clicked on Hornresp in David McBean's RECENT posts ?
Hi
If I click hornresp.net then I do did come to the right place, but I get the Joynic.com site if I agree with the hornresp automatic update when start it.
I did try more times.
I have now put everything in for let see the error, or my error for the time being.
Wel not do fall my face off
I have try again to export the horn data, en no what now is everything fine
I thought a pc did not make mistakes, only software. but after the lightning hit on the nabure his house who did catch fire my pc do strange behavior, but works further normally, except also sketchup do give errors, give message that drawn is damaged and did repair it, in sketchup screen refresh do not work properly so jumping picture special when drawn is complicated,
Oke it is off topic, but hornresp did yesterday also very strange, today it is okay again.
Old 14th May 2013, 10:42 AM   #3473
Originally Posted by David McBean View Post
Hi Kees,
Kind regards,
David
Hi David
I did put the pc on and now suddenly it is oke, like with your sample, can lightning give the pc damage like this? I do not think, a half pc is not possible, it works or not.
I have done a virus scan, did because of your automatic update in hornresp did bring my in the joy site as post earlyer. I did also make the update, maybe you can try the version before the last one to replicate the error again, then we now what is the cause in one try.
thanks.
kees
Old 14th May 2013, 01:00 PM   #3474
I have found it, notepad does this, put it wrong, but now I have tryed a couple times to open with it it is oke, the faulty one first is now suddenly also oke, it is not hornresp who do that wrong but notepad.
regards
Old 15th May 2013, 12:59 AM   #3475
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Thanks for letting us know that you found the problem.
You might use excel or libre office for this...
Dan
Old 15th May 2013, 08:46 AM   #3476
Hi Kees,
Releases of Hornresp before Version 32.00 will direct users to the old download site, which for some reason has now become Joynic.com.
Hornresp Version 32.00 and later, will direct users to the new download site Hornresp.
Kind regards,
David
www.hornresp.net
Old 16th May 2013, 11:09 AM   #3477
Hi David
Can I do model a tractrix horn with mid and High speakers? and how to start, maybe that is a to big question to explane but I can also search.
Do you have removed the filter wizzard? I don,t see it anymore.
Further amazing program, the best there is, I mean that.
regards
kees
Old 16th May 2013, 11:29 AM   #3478
more10 is offline more10  Sweden
Push "t" while cursor is in the L12 field. L23 must be 0,0.
Old 16th May 2013, 11:32 AM   #3479
Hi David
The error I get with export horn data is a problem within hornresp, sometimes it go oke but that is maybe because of the setup.
the first part S1 give a error.
Length (cm) Area (sq cm) Radius (cm) Angle (deg) Side Len (cm) Height/2 (cm) Top Len (cm) Width/2 (cm) Width Flare
0.000000 135.000000 6.555291 1.754989 0.000000 (here 0.013357 need 16.500000) 0.000000 (Here 2526.810303 needs ?) Uni
the second part S2 and the rest is oke.
0.000000 185.480000 7.683757 1.497471 0.000000 16.500000 0.000000 2.810303 Uni
It has nothing to do with notepad what I say in precious post..
Well I did close hornresp and make a new horndata file, and now it is good.
S1
0.000000 135.000000 6.555291 1.754989 0.000000 16.500000 0.000000 2.045455 Con
I have did some tests, with a conical flare it is oke, with a uni flare it is not see zip example.
regards kees
Old 16th May 2013, 09:11 PM   #3480
NEO Dan's Avatar
Hi Kees,
It would be nice if you would export the Hornresp record so we may try and replicate your results.
Dan
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 10:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
