Hornresp
Hornresp
Old 18th April 2013, 08:27 AM   #3361
David McBean is offline David McBean  Australia
Default Bug Report
Hi Everyone,
I have found my first bug in the new Filter Wizard tool :-).
Pressing Ctrl+Alt+B does not update the electrical impedance baseline.
This will be fixed in the next release - probably tomorrow.
Kind regards,
David
www.hornresp.net
Old 18th April 2013, 08:55 AM   #3362
Originally Posted by blo06 View Post
I'm browsing the help to figure how it works, and that is clear, but the help itself is not user friendly... Something to do in this part I'm afraid, like direct access to chapter, search, etc...
Hi B.,
All I have tried to do with the Help file is to ensure that every available feature is briefly described, essentially in summary form.
Perhaps someone might like to prepare and post a more comprehensive "Hornresp Filter Wizard Tutorial"... :-).
Unfortunately I do not have any information on how to generate proper "Windows type" Help files for Visual Basic 6 programs, and I have not been able to find anything particularly useful via Google. If anyone has this information, and would be prepared to share it with me, I would be most grateful.
Kind regards,
David
www.hornresp.net
Old 18th April 2013, 09:09 AM   #3363
Sabbelbacke is offline Sabbelbacke  Germany
@David
Does this help
Microsoft HTML Help Downloads (Windows)
http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
Old 18th April 2013, 09:55 AM   #3364
Zero D is offline Zero D  United Kingdom
@ David McBean
I didn't miss your Post, it's just that i hadn't pressed Calculate FW doesn't appear until then.
My sincere gratitude to you for coding these features, & so quickly too As i said previously when i was trying to encourage you to include even only a HPF, it would make ALL the difference, & it has & will !
You have gone even further than i had hoped for, & included HP/BP/LP, & also managed to code for both Active & Passive filters in the process !
Never say never, hey
All the best
Old 18th April 2013, 12:15 PM   #3365
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Getting Better!
Mark
www.kravchenko-audio.com
Old 18th April 2013, 03:23 PM   #3366
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Hi Blo06,
You could open the help file in a text editor or browser and use the search function(ctrl)+(F), or you could make the help file into a document if you prefer. But realize that David does make changes to the file as needed, so you could be spending some time managing the document instead of using/learning Hornresp.
Dan
Old 18th April 2013, 08:27 PM   #3367
Lightbulb Help File info
HR has a Help File Export function
You can Save it as a .txt file & then view it in for eg Notepad. You can then also edit it if you wish and/or convert it to another format such as PDF etc. Presuming you have software to convert to a PDF of course
Here's how from 1 -4 to Save as a .txt file
Old 19th April 2013, 06:04 AM   #3368
Default Hornresp Update 3200-130419
Hi Everyone,
The above bug has now been fixed.
Kind regards,
David
www.hornresp.net
Old 19th April 2013, 06:15 AM   #3369
Originally Posted by Silent Screamer View Post
Has the hornresp website moved?
Hi Silent Screamer,
Yes. Click on the link below my name in this post.
Kind regards,
David
www.hornresp.net
Old 19th April 2013, 06:42 AM   #3370
Originally Posted by Sabbelbacke View Post
Does this help
Hi Sabbelbacke,
Thanks for the links.
I checked out these pages myself, some time ago, when I first started looking for information on creating a standard Windows-type help file. I had been hoping to be able to compile the file as an integral part of Hornresp, which I understand is possible with VB6. I would prefer not to have to work with HTML if I can avoid it.
After thinking about it some more last night, I realised that I probably wouldn't get around to shifting from the existing Hornresp Help file text-based format anyway, even if I knew how to do it. I find that I am really more interested in the programming side of things, rather than spending precious time documenting how everything is supposed to work :-). My current arrangement allows me to edit the help file very quickly indeed.
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
