Hornresp
Hornresp
Old 4th April 2013, 05:31 PM   #3271
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I'll thrown in my
The idea of passive filters is an interesting one. We have always had the option to export the impulse, and from there you can do all manner of acoustic filter "stuff" externally.
For me the need is for physical performance with active HPF, passive would also be nice. Being able to see what happens with excursion at the bottom of the pass band would be of HUGE benefit, and you can't get that working from an impulse.
Dan
Old 5th April 2013, 07:16 AM   #3272
Jmmlc is offline Jmmlc  France
R.I.P.
Originally Posted by NEO Dan View Post
I'll thrown in my
Hello,
I think both active and passive filtres are interesting to be introduced in Hornresp, but that's double work.
We can say that the active filter approach relates to Eg in the Hornresp input data window, while the passive filter approach relates to Rg.
Best regars from Paris, France
Jean-Michel Le Cléac'h
Old 5th April 2013, 07:25 AM   #3273
Sabbelbacke is offline Sabbelbacke  Germany
Originally Posted by Jmmlc View Post
Hello,
Not necessarily. The calculations can be almost the same, the active part can simply be fed to a constant impedance instead of the changing one on a real speaker.
How about implenenting a plugin interface at Rg and Re, so every filter one desires can be flunged in there, let´s build some VST Interface, this way David doesn´t have to do the filterstuff himself an we can even implement FIR Filtering (hihi, just playing with my mind, just kidding).
Old 5th April 2013, 07:33 AM   #3274
David McBean is offline David McBean  Australia
If we limit the choice to a high pass filter, with a few more components than in your schematics we can also provide impedance equalization and HF uplifting.
(I put 2 RLC impedance equalizors but one could eventually be enough, even if with horns there is often more than 2 peaks of impedance).
Hi Jean-Michel,
Thanks for the feedback.
If I understand correctly, the two HF uplift components are the only ones missing from my template (if we assume that only one RLC impedance equaliser is required).
Would the template still be worth having even if HF uplifting was not allowed for?
Kind regards,
David
www.hornresp.net
Old 5th April 2013, 07:41 AM   #3275
I´d even go either for the simple solution of just having some High-Pass Filtering and just stick with that - or go all the way and do the matrix thing, so all cases are covered. In Jean-Michels Example, you have:
- Two Impedance eq for the lower and upper end
- HF uplifting
- Highpass uo to 3. Order
Notch Filters, Lowpass, Allpass, etc.. - are still missing.
Of course, one could argue that you don´t need those a lot - but I bet there are people who will be asking for it (e.g. someone who wants to get rid of a resonance in a mid-Horn System and either wants to use a helmholtz resonator as a mechnical solution or do it in the x-over...)... So people will ask for extensions of the limited model and maybe its less work to do the flexible soultion in the first place ?
Old 5th April 2013, 07:55 AM   #3276
Hi Everyone,
Thanks for all your filter comments. If anything was to be done in Hornresp, the functionality would be confined to passive filters comprised of pure resistors, capacitors and inductors, and most probably be restricted to networks that can be specified within the 12 component template previously posted.
So don't get too excited... :-).
Kind regards,
David
www.hornresp.net
Old 5th April 2013, 07:56 AM   #3277
R.I.P.
Originally Posted by David McBean View Post
Hi Jean-Michel,
Kind regards,
David
Hello David,
Your template will be definitevely worth.
Eventually for every RLC circuit a wizzard could be opened at demand in order to introduce the resonance frequency and Q...
Circuit Theory/RLC Circuits - Wikibooks, open books for an open world
Best regards from Paris, France
Old 5th April 2013, 08:09 AM   #3278
Hi Sabbelbacke,
I must be missing something - isn't the two-component network shown in the attachment a simple low pass filter?
It can be specified using the previously mentioned template.
Kind regards,
David
www.hornresp.net
Old 5th April 2013, 08:17 AM   #3279
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
One suggestion: if each series LRC-branch in David's template could optionally be changed to a parallel RLC circuit, we could get quite a bit more flexibility.
-Bjørn
Dynamics to the people!
Old 5th April 2013, 08:32 AM   #3280
Hi Jean-Michel,
Thanks for confirming that the 12 component template would still be of some value.
The filter tool would show the SPL response and the diaphragm displacement resulting from having a filter network between the amplifier output and the loudspeaker input. The tool would accept R, C and L component values as specified by the user, but not deal with resonance frequency and Q values.
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
