Hornresp - Page 326 - diyAudio
Old 3rd April 2013, 12:40 PM   #3251
Jmmlc is offline Jmmlc  France
R.I.P.
Originally Posted by Sabbelbacke View Post
David is old enough to speak for himself, but didn't he clearly say that he doesn't want to include filtering in hornresp? I think we should respect that.
Or did I miss something and did David open the door to implementing filters ?
Hello Sabbelbacke,
My message was intended to propose to David if needed, my help to integrate such filters in a same way David and me used to collaborate to introduce the "Impulse Response" module and the "Spectrogram" module, that surely many like to see now in Hornresp.
Best regards from Paris, France
Jean-Michel Le Clac'h
Old 3rd April 2013, 12:42 PM   #3252
Mark Kravchenko
mwmkravchenko's Avatar
As a little fly on the wall listening...
Mark
www.kravchenko-audio.com
Old 3rd April 2013, 01:08 PM   #3253
Dont get me wrong, Id love filters in hornresp, too I just got the impression that people ask a lot about something where david said "no" already.
I also know that once you start to put passive filters in hornresp, there is no "this is enough"...
If hornresp were to get filter capability, Id strongly recommend to implement something like in BoxSim, so ALL possibilities are there (important impedance corrections, notches, etc..). Maybe the Boxsim guys want to share their work?
Old 3rd April 2013, 01:41 PM   #3254
tb46 is offline tb46  United States
Default Post #3242
Hi David,
Thanks for reinstating the horn throat sound pressure and throat particle velocity charts, and the other changes. This is very much appreciated.
Oliver
Old 4th April 2013, 09:09 AM   #3255
Originally Posted by Jmmlc View Post
About introducing filters in Hornresp at least we should discuss about some requirements and priorities.
Hi Everyone,
With regard to Jean-Michel's comment, would it be sufficient to be able to specify a passive filter in accordance with the attached network template, with only those components actually required being included?
If so, then a real time 'Filter Wizard' could be quite a nice thing to have... :-).
R = resistor, C =capacitor, L = inductor.
Kind regards,
David
www.hornresp.net
Old 4th April 2013, 09:11 AM   #3256
Passive filtering between the drive emf and the speaker driver.
Or
Active filtering before the drive amplifier, leaving the drive emf to speaker driver link uncontaminated.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th April 2013, 09:22 AM   #3257
Hi Jean-Michel,
Thanks for your kind offer, but I should be okay. The circumstances are a bit different this time - I better understand the underlying theory :-).
Kind regards,
David
www.hornresp.net
Old 4th April 2013, 09:26 AM   #3258
Hi Oliver,
You're welcome. As you can see, I took note of your comments :-).
Kind regards,
David
www.hornresp.net
Old 4th April 2013, 09:57 AM   #3259
R.I.P.
Originally Posted by David McBean View Post
Hi Everyone,
Hello David,
If we limit the choice to a high pass filter, with a few more components than in your schematics we can also provide impedance equalization and HF uplifting.
(I put 2 RLC impedance equalizors but one could eventually be enough, even if with horns there is often more than 2 peaks of impedance).
Old 4th April 2013, 11:01 AM   #3260
I love the filtering in Boxsim, it looks like this:
It is possible to put in whatever one wants, no limits. I could ask Uwe, the author, if he would share his modul of the function...
Another idea in the same direction would be to take some parts of SPICE and integrate them.
SPICE - Wikipedia, the free encyclopedia
Either way, both active and passive filtering are interessting, if Ih had to choce, Id take the passive one (after all, aktive Filtering is "boring" in this regard, since there is no dependancy on the impedance of the speaker system... The real interesting things happen when you take the real impedance of the speaker into account).
At least, wed need:
- Coils with editable R and mH
- Capacitors
- Resistors
- Shunts
The passive filtering should be right before "the box", not behind the amp, in front of the cable:
amp - cable - x-over - speaker/box
AjHorn does it like this:
nod as flexible as BoxSim, but sufficent.
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright 1999-2017 diyAudio
