Hornresp
Hornresp
Old 7th March 2013, 10:23 AM   #3191
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Sharpshootin bug killer!
Much appreciated David.
Mark
www.kravchenko-audio.com
Old 7th March 2013, 02:19 PM   #3192
epa is offline epa  Netherlands
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 7th March 2013, 04:41 PM   #3193
tb46 is offline tb46  United States
Hi David,
Great work as always. Hornresp has definitely risen to be a professional product.
I know you don't want to add filter functionality into Hornresp, but [ :-) ], it would be great if you could enter the capacity for designing woofers with a series capacitor.
It would make a lot of sense to have a Cg together with Rg, both of which could be used to better define the amplifier output impedance and the cable impedance (as well as used as series input components).
I have been doing this in AkAbak, but it does not have the Wizard/Slider functionality, and thus takes much more time.
Whether you could get to this or not, I just cannot thank you enough for your great product. Hornresp has opened up a whole new world of design to me that I would otherwise not have had the time to pursue. Just wish I would have had it in the 1960s or '70s. :-)
Thanks again.
Oliver
Old 7th March 2013, 09:14 PM   #3194
Mark Kravchenko
Hornresp
If only we had computers like the ones we have now i the 60's and seventies!
Mark
Old 7th March 2013, 10:35 PM   #3195
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
That's it Mark, just add some vacuum tubes to that AMD POS you got under the desk. A tube headphone amp ought to fill the bill. And with the 5v line outs on the PC it's bound to make some nice harmonics in your earbuds...
Dan
Old 7th March 2013, 11:37 PM   #3196
Mark Kravchenko
Hornresp
That's it!
Make fun of my peglegged AMD DoZer chip!
Wurst piece of poop I ever did buy says I.
But it is half working.
Mark
Old 8th March 2013, 06:42 AM   #3197
David McBean is offline David McBean  Australia
Hi Oliver,
Nice try, but sorry - it's not going to happen :-).
Kind regards,
David
www.hornresp.net
Old 8th March 2013, 01:39 PM   #3198
Hi David,
Thank you anyway. I just thought this might be a relatively simple major improvement of your software. :-)
Oliver
Old 10th March 2013, 08:52 AM   #3199
Default Hornresp Update 3120-130310
Hi Everyone,
A new 'Radiation Angle' tool has been added to Hornresp. It provides a graphical view of the placement of the loudspeaker and the solid angle into which the loudspeaker radiates, as given by the Ang input parameter value.
The new Tools menu command is enabled when the Ang parameter has the focus. The tool can also be selected by double-clicking the parameter in edit mode.
It is still also possible in edit mode to directly enter a value into the Ang input field, and to toggle values by double-clicking on the Ang label.
See the attached example screenprint.
Kind regards,
David
www.hornresp.net
Old 10th March 2013, 11:35 AM   #3200
Mark Kravchenko
Hornresp
Nice touch.
Thanks David!
Mark
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
