Hornresp
Hornresp
Old 20th February 2013, 07:10 AM   #3181
David McBean is offline David McBean  Australia
Originally Posted by mashaffer View Post
Not trying to be contrary David and I really appreciate your work.
Hi Mike,
Not a problem - many thanks :-).
I have been thinking about the difficulty you experienced trying to run the latest release using Wine. If the older version that works okay for you is 29.20 or earlier, then I suspect the culprit is the automatic check the program now does on startup to see if the latest release is being used.
Hornresp
I am guessing that perhaps Wine has difficulty coping with the call the program now makes to the Hornresp Internet download site (if the user is not connected to the Internet, the resulting error is normally trapped and handled internally).
Kind regards,
David
www.hornresp.net
Old 20th February 2013, 01:14 PM   #3182
mashaffer is online now mashaffer  United States
That could be the case. I am not sure whether wine has access to the internet on my system as I have never tried. For security reasons it may well not. I am using 29000-120413. As far as I can tell the only thing that doesn't work is the horn segment wizard which I have been able to easily do without.
The only reason I drive the 91 Colony Park is that I can't afford a 65. Me old school? Couldn't be.
Old 21st February 2013, 05:08 AM   #3183
Hi Mike,
Is only when you double-click a segment input value that Hornresp crashes, or does it also fail when you highlight a segment value and then select the menu command Tools > Horn Segment Wizard?
Kind regards,
David
www.hornresp.net
Old 22nd February 2013, 12:27 AM   #3184
Either way. I get the Hornresp has encountered a serious error dialog and then it crashes.
Old 22nd February 2013, 05:43 AM   #3185
Hi Mike,
Thanks.
That is interesting - another Hornresp / Wine incompatibility, it seems. Unfortunately I don't think there is anything that I can do about it. I have noticed that text can sometimes be displayed incorrectly also - see attached example screenprint (one of yours).
Kind regards,
David
www.hornresp.net
Old 3rd March 2013, 04:17 AM   #3186
Default Hornresp Update 3110-130303
Hi Everyone,
A minor anomaly in the operation of the "file delete" functionality has been fixed.
The Delete button should not be enabled when Hornresp.dat is the only data file available.
Attachment 1 shows the old functionality. Attachment 2 shows the new functionality.
Kind regards,
David
www.hornresp.net
Old 3rd March 2013, 08:11 AM   #3187
WayneK is offline WayneK  Australia
Hi David,
When trying to print out the response graph and input data I get an error Run-time error '9': Subscript out of range. I am running windows XP and even downloading the latest version results in the same error
Wayne
Old 4th March 2013, 03:57 AM   #3188
Hi Wayne,
Many thanks for this - I get the same error as you. I will investigate and let you know once the problem is fixed.
Kind regards,
David
www.hornresp.net
Old 4th March 2013, 06:06 AM   #3189
Default Hornresp Update 3110-130304
Hi Everyone,
The printing bug reported in Post #3187 has now been fixed.
Again - my thanks to Wayne for making me aware of this problem.
Kind regards,
David
www.hornresp.net
Old 7th March 2013, 04:38 AM   #3190
Default Hornresp Update 3110-130307
Hi Everyone,
Some minor internal code refinements have been made. They do not affect the operation of the program in any way.
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
