Old 16th February 2013, 07:28 AM   #3171
Default A Word of Warning
Originally Posted by NEO Dan View Post
Speaking of Hornresp versions, I maintain a publicly available repository just in case.
Hi Dan,
I've said it before and I'll say it again - retaining old versions of Hornresp is hazardous to your health :-).
If you do happen to inadvertently open your current Hornresp.dat data file using a superseded version of Hornresp, then you run the very real risk of irretrievably corrupting your data file.
Do what I do, and only keep the latest version of Hornresp. If it's good enough for me, then it should be good enough for you :-).
I can't stress this strongly enough!
Don't say you haven't been warned...
Kind regards,
David
www.hornresp.net
Old 16th February 2013, 09:43 AM   #3172
Mark Kravchenko --- www.kravchenko-audio.com
mwmkravchenko's Avatar
Oooooh.
Now this is true for the last few updates yes?
Mark
Old 17th February 2013, 05:49 AM   #3173
Hi Mark,
From Version 19.10 onwards, Hornresp should automatically detect when the format of a data file is more recent than that of the program being used.
To illustrate:
1. A data file originally produced using Hornresp Version 31.10 will generate the following error message if opened using Hornresp Version 19.10.
"Must use Hornresp Version 29.00 or later with current data file."
(Version 29.00 is the last time that the data file format was changed).
2. A data file originally produced using Hornresp Version 31.10 will be corrupted if opened using Hornresp Version 19.00.
To avoid any possibility of data file corruption, I strongly recommend that old versions of Hornresp be deleted.
Kind regards,
David
www.hornresp.net
Old 17th February 2013, 06:51 AM   #3174
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Hi David,
Are you arbitrarily version locking the .dat file or is going to be good across all versions that share the same data structure? I see now this is already addressed.
You might want to consider an import of the database if you are changing the structure leaving the old version intact. Thus to never irrecoverably hose the DB ever.
If you let me know when you made/make changes to the structure I can group the old versions in folders as a preventative measure. All versions prior to 29.00 have been placed in a separate folder.
I also run Hornresp from Dropbox, it has 30 days minimum history of every saved change made to a file. All you have to do is log in to the web interface to revert or download a previous version. Butt covered in triplicate really. You might consider putting the Hornresp development project on Dropbox, it could come in handy or even save your butt.
I started saving Hornresp when I found out you were not, sometimes you need to go back. How do you find out where/when an error was introduced without a prior version?
Dan
Old 18th February 2013, 06:32 AM   #3175
Hi Dan,
I see that the oldest version of Hornresp you have is 2840-110427. Because this is later than version 19.10 there should be no data file corruption problems.
All I require for the debugging process is a detailed description of the problem - it does not matter where/when the error was introduced.
I still don't understand why anyone should find it necessary to keep superseded versions of Hornresp... :-).
Kind regards,
David
www.hornresp.net
Old 18th February 2013, 09:53 AM   #3176
Originally Posted by David McBean View Post
... I still don't understand why anyone should find it necessary to keep superseded versions of Hornresp... :-). ...
This is standard practice in the IT industry, born of long and bitter experience. We need the ability to roll back, sometimes more than one version. No matter the reassurances from the vendor, there is no guarantee that a bug fix will not break something else that we rely on. We spend a lot of time and money regression testing to reduce the risk of this happening - and then sometimes it does anyway. I doubt that Hornresp is business critical for any of its users, but hard learned habits are even harder to break...
Old 19th February 2013, 01:19 AM   #3177
I have an older version because it works. I tried downloading the latest version taking the precaution of putting it in its own folder totally separate from my working copy. When trying to start it in wine I got the splash and then nothing. No error or crash or anything. My existing version works fine for the most part (crashes if I double click on a horn segment but otherwise does what I need).
If We The People refuse to hear the truth we will be ruled by liars.
Old 19th February 2013, 03:59 AM   #3178
soongsc is offline soongsc  Taiwan
soongsc's Avatar
This practice allows for anyone in a group to take over tasks with little risk. Also when code gets over a certain size, it becomes more difficult to maintain. So additional logs, data passing, and explanations are kept as well.
Hear the real thing!
Old 19th February 2013, 06:25 AM   #3179
I surrender - it seems that I am fighting a losing battle here... :-).
Kind regards,
David
www.hornresp.net
Old 20th February 2013, 01:06 AM   #3180
Not trying to be contrary David and I really appreciate your work. I too plan to get with the program and use the latest version once I get a new computer that is compatible.
I will be getting a new Intel based computer for a virtual organ project as soon as I scare up the funds and I plan to have it triple bootable with Windows 7, Ubuntu and Puppy. Then I will have a native windows machine on which to run the latest versions.
Hornresp Class FlipC Subwoofers 8 3rd November 2008 06:23 PM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2013 diyAudio
