Old 1st February 2013, 06:34 AM   #3151
Originally Posted by blo06 View Post
16 would be good
Hi Blo,
The Hornresp comment field can be up to 76 characters in length - that's too long a file name for me. 16 characters it will be :-).
Hopefully I should be able to release an update sometime tomorrow.
Kind regards,
David
www.hornresp.net
Old 1st February 2013, 06:36 AM   #3152
blo06 is offline blo06  France
Originally Posted by David McBean View Post
Hi Blo,
Kind regards,
David
All right !!
Thanks for that !!
Blo
Old 1st February 2013, 07:36 AM   #3153
In reality, the vented-enclosure and port tube each have frequency-dependent impedances
To make things clearer I should perhaps have said "quite complex frequency-dependent impedances".
Kind regards,
David
www.hornresp.net
Old 2nd February 2013, 04:11 AM   #3154
Default Hornresp Update 3110-130202
Hi Everyone,
The maximum allowable length for Hornresp file names has now been increased from 8 to 16 characters. The file Open / Save form has also been widened to ensure that even under "worst-case" conditions, file names having 16 characters will be fully visible for all standard screen resolutions and text sizes - see attachment.
Kind regards,
David
www.hornresp.net
Old 3rd February 2013, 02:38 PM   #3155
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Thanks David,
This is great! I have some rather cryptic names in my export folder.
Dan
Old 4th February 2013, 06:11 AM   #3156
Originally Posted by NEO Dan View Post
Thanks David,
Hi Dan,
I'm glad you like it :-).
Blo06 really deserves the thanks, for suggesting the change in the first place.
For obvious reasons only version 31.10 or later will be able to save and open files having names longer than 8 characters.
Kind regards,
David
www.hornresp.net
Old 4th February 2013, 11:47 AM   #3157
Mark Kravchenko --- www.kravchenko-audio.com
mwmkravchenko's Avatar
So we thank the messenger and the sender!
Thankyou again.
Mark
Old 12th February 2013, 06:17 AM   #3158
Default Hornresp Update 3110-130212
Hi Everyone,
The F6 function key Imperial Conversion tool now also works with the radius horn R input parameter.
Kind regards,
David
www.hornresp.net
Old 12th February 2013, 12:48 PM   #3159
Although I like metric. All my materials still come in nominal inches.
So this is a very useful addition.
Thank you David.
Mark
Old 12th February 2013, 12:54 PM   #3160
BP1Fanatic's Avatar
VERY useful addition!!!
Hornresp Class FlipC Subwoofers 8 3rd November 2008 06:23 PM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2013 diyAudio
