Hornresp
Hornresp
Old 24th January 2013, 07:04 PM   #3121
tb46 is offline tb46  United States
Hi David,
Just updated to 3100-130124, and when resetting S1 to 0.01 I get an error in Par and Exp, but not in Con. Please, see attached pictures.
Oliver
Old 24th January 2013, 09:05 PM   #3122
Kolbrek is offline Kolbrek  Norway
Kolbrek's Avatar
The first message is a warning, telling you that the horn is so large compared to the cutoff wavelength that the plane wave model is no longer valid. It has always appeared for multisegment horns, when Cir for one or more of the segments exceeds one.
-Bjørn
Dynamics to the people!
Old 24th January 2013, 09:21 PM   #3123
Hi Bjorn,
I'm aware of that (Post #3122), the second picture shows the error, and I think it didn't occur in this or similar simulations before (I don't know when it changed).
Oliver
Old 25th January 2013, 06:23 AM   #3124
David McBean is offline David McBean  Australia
Hi Oliver,
Brilliant pickup - many thanks!
The error was introduced as a result of making the schematic diagram perfectly symmetrical under all conditions. The problem will be fixed in the next release - likely to be tomorrow.
Kind regards,
David
www.hornresp.net
Old 25th January 2013, 08:19 AM   #3125
Originally Posted by AndrewT View Post
David and others,
could you talk us through what the "shape" of those plots is telling us?
There are some small ripples on the flanks, what do they mean?
There is an asymetry over the peak, what does that mean?
Why does the black have a more pronounced ripple at ~900Hz
What is the difference in the red and the black?
Why the difference in slopes before and after the peak? Red is slow before and fast above, whereas black is fast below and slow above?
Why is the red at zero at both limits whereas the black is zero at low limit and 1 at the high limit? Is it exactly 1? Why 1, what does that mean?
Hi Andrew,
This should answer most of your questions:
http://audioamateur.com/media/aa/kolbrek2884.pdf
If things are still unclear after reading Bjørn's article, please let me know.
Kind regards,
David
www.hornresp.net
Old 25th January 2013, 11:28 PM   #3126
Brian Steele is offline Brian Steele  Grenada
David, I'm getting a LOT of "Run-Time error '11': Division by zero" errors with the Horn Loudspeaker Wizard in latest version of HornResp (3100-130124) ...
www.diysubwoofers.org
Old 26th January 2013, 06:12 AM   #3127
Thanks Brian.
Unfortunately it is another unforeseen undesirable outcome of the recent "improvement" (?) made to the schematic diagram. The problem will be fixed in the next release - now probably tomorrow.
Kind regards,
David
www.hornresp.net
Old 26th January 2013, 09:25 AM   #3128
Default Hornresp Update 3100-130126
Hi Everyone,
Hopefully the bugs reported by Oliver (Post #3121) and Brian (Post #3126) have now been fixed.
Kind regards,
David
www.hornresp.net
Old 26th January 2013, 07:21 PM   #3129
Hi David,
All looks good so far. Thanks.
Oliver
Old 26th January 2013, 07:39 PM   #3130
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Yay!
Mark
www.kravchenko-audio.com
HornrespHide this!Advertise here!
Hornresp Class FlipC Subwoofers 11 4th June 2016 06:33 AM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
